max driveshaft angle on d70
Old May 10, 2006 | 10:48 AM
countryF150's Avatar
countryF150
I have a 1979 f250 ext cab long box w/a rear d70 in it and was wondering what the max pinion angle/ driveshaft angle i can have is.
thanks
Old May 10, 2006 | 11:28 AM
averagef250's Avatar
averagef250
Axle doesn't matter. The series of U-joint determines the max angle. if it's a ford 70B axle it should have a 1350 U-joint. The 1350 has 1 3/16" caps and is 3 5/8" across (this is from memory, so could be off here). As I remember a spicer 1350 has a max angle of 20 degrees. The more angle you run with any U-joint the shorter it's life gets exponentially. At 20 degrees it has like a 5% lifespan. Keep in mind the U-joints must also be in perfect phase and U-joint angles must match at each end of a driveline.
ceetwarrior
Mar 7, 2018 08:12 AM
rock2610d
Oct 27, 2016 11:49 AM
Jointasset
Jul 5, 2016 08:24 PM
orre_s86
37
Jun 5, 2016 06:14 PM
Munkey
Sep 6, 2003 03:48 AM
