Sponsored by: Auxito
Tire Size?
Old Jul 1, 2010 | 02:41 PM
ss20403's Avatar
ss20403
Tire Size?
Does anyone know if I can run 275/70/R16 BFG AT KO's on my Ford F150 4x4 without rubbing? I dont have a lift kit and dont want one. It has stock rims and came with 245/75/R16's. According to my calculations the 275/70/16 is only 0.5 inch taller but almost 1.2 inches wider. I know they will fit but just dont want rubbing while turning sharp or bending of any fender metal...
Thanks
Old Jul 1, 2010 | 05:49 PM
steve(ill)'s Avatar
steve(ill)
should be o.k. mine has 265 x 70 x 17 inch
Old Jul 1, 2010 | 10:51 PM
93 mix 'n match's Avatar
93 mix 'n match
mines 265/70 16s. they should be fine.
Old Jul 3, 2010 | 10:39 PM
cdatj2's Avatar
cdatj2
my 03 has 285x75x16 on it lol not my choice but were on it when i got it and they dont rub at all but have to have the pmc flashed to handle the taller tires, dont let lot boys put tires on a rig like they did cause you will get monsters on it
Old Jul 14, 2010 | 05:50 PM
Bltfordtuff's Avatar
Bltfordtuff
sorry if this sounds dumb, but what is the pmc?
Old Jul 14, 2010 | 08:11 PM
steve(ill)'s Avatar
steve(ill)
older trucks needed a new speedo gear in the transmission to compensate for the new BIG tires... new trucks have this programed into the computer. the computer needs to be "flashed" or reprogramed at the dealer to compensate for the gear (tire) change.
Old Jul 14, 2010 | 11:14 PM
mikesheldon's Avatar
mikesheldon
No, your OEM tire size is P235/70R16 104S not "235/R16". All of the numbers and letters in the tire size description are important, particularly the "104" since that tells us the tires load carrying capacity.
Towing capacity is set by the vehicle and the specs can be found in your owners manual or possibly on the Vehicle Information Tag inside the drivers door frame. Changing to P255/70R16 109S tires will not increase your towing capacity one bit, nor will it likely improve stability although it was an optional size on your truck and you could install such tires with no problems except for a reduction in speedometer and odometer accuracy.
If you want to improve stability while towing check the maximum inflation pressure listed on the sidewall of your tires. It is probably 44 psi. Normally the tires on your truck would be inflated to 35 psi front and rear but to improve stability while towing you could increase that to 44 psi if allowed by your tires. You don't gain any load carrying or towing capacity above 35 psi but the higher pressure will produce less squirm. Just remember to drop the pressure back down when you are not towing.
Old Jul 16, 2010 | 12:03 AM
slomafarms's Avatar
slomafarms
do you really have to have it reflashed? the guy i bought my truck from put 265's on it and it works just fine for me. im getting new tires in about a week. just dont know weather to stick woth the 265's or 285's
Old Jul 16, 2010 | 02:01 PM
galaxie641's Avatar
galaxie641
You don't have to, just be aware your speedo and odo will be off a certain %
Old Jul 17, 2010 | 08:06 AM
cdatj2's Avatar
cdatj2
with the 285 on my speedo is off 10 percent and have to remember when on the hiway to drop lol lots easier with tires that dont wear out very fast to spend the 40 bucks to get it flashed and then no worries and no redlights in the mirror when you forget to account for that 10 percent
Old Jul 17, 2010 | 11:58 AM
slomafarms's Avatar
slomafarms
i checked my speedo with my GPS and its off by .5 mph, is there really a need to get it flashed?
Old Jul 18, 2010 | 08:24 AM
cdatj2's Avatar
cdatj2
for .5 no you dont unless you want to be **** about it, i wouldnt if mine was less than 5 off but is a bit more at freeway speeds, around town i dont worry to much about it but when i take my wife on a road trip is when have to pay attention
Old Jul 23, 2010 | 09:53 PM
gtiguy's Avatar
gtiguy
i have 285 75 16 and they dont rub at all!
Old Jul 23, 2010 | 10:56 PM
slomafarms's Avatar
slomafarms
i get my duratrac's in the morning!
itsnunya
Apr 13, 2016 03:18 PM
Go Aweigh2452
Mar 26, 2013 01:20 AM
CanadianBlake
Jun 2, 2012 10:49 AM
jdhudall
1997 - 2003 F150
Dec 2, 2007 07:35 PM
sandman3510
Nov 18, 2007 11:24 AM
