Hi I am the owner of a 2001 F150 SuperCrew 4x4 lariat with 265/70/R17 tires on it and I lifted it 2" what is the largest tire size that will fit with no rubbing??? I know 275's will fit before any lift I want to go with 285/70-R17 so before I spend $1000 on new tires I would like to see if anyone has done this before!
Hello ,I have a 04 4x4 5.4 which I have 22'' rims with 285/45 falcons tires on it .The only problem I do have is what they call a wheel nibble .This is a back and forth vibration in the steering wheel at speeds over 100 km a hour .My wheels have been road forced balanced ,so not sure what is causing it ,had a new rack also under warranty. smittydoes
