07 F150 A/C problems
Old Jul 1, 2010 | 10:18 AM
tonebone's Avatar
tonebone
Recently purchased my 07 with 30k miles. Sold my 97 F150 at same time. Problem is that the 07 seems to lose its cool at stop light/signs. Not completely, but noticeable to me and the family. We usually run it on max A/C to maintain a comfortable temp. Never had to do that with my 97. Had it checked out at local garage that I trust and they say pressures and levels are fine. But state that they have seen times when simply replacing the freon has solved similiar problems. I have warranty at dealer, but am afraid that with the system checking out ok, that I simply will get hit with a diagnostic charge instead of a freon charge. Does anyone have a similiar situation with this year Ford A/C systems? My 97 had a flawless A/C system. Any help/comment appreciated...............Thx
Old Jul 1, 2010 | 11:14 PM
krane operator's Avatar
krane operator
Some trucks were overchared and others undercharged with freon from factory, but if it checked out ok, did they inspect the fan clutch. Some trucks had a problem with the blend door. If you do a search you will find info about it. Hope this helps . Are you shure you are not still under factory bumper to bumper warranty? They should not charge you nothing.
3cornersranch
Aug 13, 2010 02:56 PM
Chris 97 F150
1997 - 2003 F150
Jun 12, 2008 02:43 PM
Bobby82490
May 16, 2008 04:42 AM
Vin Man
Apr 20, 2004 03:02 PM
Chuckymadness
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Sep 18, 2003 11:38 PM
