Sponsored by: Auxito
A/C probs
Old Jun 10, 2008 | 01:22 AM
Chris 97 F150's Avatar
Chris 97 F150
A/C probs
i replaced A/C components, such as accumulator, compressor, and the orifice tube and had other comps. cleaned and blown out...97 4.6L
i began to recharge the system and charged up to about 50 psi on high pressure side and it seemed to stop recharging...if i have the hose off of the low pressure line, it will blow the freon out like it should when i have it hooked to the accumulator, but it ended up stoppin charging into the low pressure side...is there air in the system and cant charge anymore? or what is the problem and why is it not recharging anymore bcuz i still have quite a bit of freon to put in it so that the compressor will start turning
Old Jun 10, 2008 | 10:26 AM
LxMan1's Avatar
LxMan1
You must vacuum down the system before charging it. You want it down to 29.92" vacuum for at least an hour before charging.
Once you have properly vacuumed the system, recharge it thru the low side with the system running. Add the oil charge first, then the freon.
Old Jun 10, 2008 | 12:26 PM
Chris 97 F150
ok, where can i get the vacuum tool for pretty cheap and how much pressure does it take before the compressor kicks in? and the vacuum, do you use it like charging the system, or do i have to disconnect lines and such??
oh and the compressor already is pre-oiled with 1.5oz, the sticker under the hood says max of 7oz of oil, how much should i put in it??
Old Jun 10, 2008 | 01:07 PM
KingRanchMan02's Avatar
KingRanchMan02
When the vacuum is pulled on the system, the oil, freon and any air will be pulled out by the vacuum pump. This is why you need to put oil back in before the freoan is added. By the way, you don't want to put too much freon in the system either as this can cause pressures to be too high and will result in other problems. Doing this job at home in the driveway under the shade tree can be done if you have the knowledge and the proper equipment. It doesn't sound much like you have either. You may want to get a qualified technicain to do this for you. Good luck!
Old Jun 10, 2008 | 06:30 PM
Chris 97 F150
well, i tried the vacuum pump, but there was still air in the system or the compressor isnt gettin power to compress the air i put in so that it will charge more...im gettin tired of this POS lol
Old Jun 10, 2008 | 07:42 PM
Bobby82490's Avatar
Bobby82490
Did you use gauges to see how much you vaccumed it down?.... also how long did you vaccum it down for?
Old Jun 10, 2008 | 09:17 PM
Chris 97 F150
yes i did use guages...and also vacuumed it down somewhere between 1 and 2 hours...but found the real problem, no voltage to the switch...checked with voltmeter at the plug and gettin no voltage
Old Jun 11, 2008 | 05:26 PM
Chris 97 F150
is there a relay or fuse under the hood that controls power to the compressor, because the fuse in the fuse panel inside the truck is good...no voltage to the plug going to compressor and i have jumped both low and high pressure switches with wire
Old Jun 11, 2008 | 09:15 PM
NEBFRD's Avatar
NEBFRD
Guys the vacuum pump doesn't remove any oil. It removes the "non-condensables" in the system (ie.air). You need to put the pump on and read the vacuum in microns not inches of mercury. The proper tools are unaffordable for the average DIYer. You are always best to take it somewhere to get it done by a pro. This is coming from a A/C expert.
Old Jun 12, 2008 | 10:28 AM
KingRanchMan02
I am no expert in automotive AC obviously, with a statment like that. I know enough to get around and when to get assistance.
There is oil in the compressor, the dryer, the evaporator core and the condenser core. Each of these should have a certain amount according the the manual, which varies per component.
I whole heartedly agree with this statement.
Old Jun 12, 2008 | 01:37 PM
Chris 97 F150
I, the DIYer, have fixed the problem, i have knowledge on what to do and how to do it A/C expert, just a broke wire that my lazy *** didnt want to search the whole wiring harness for...A/C running very well like brand new, and very cold i might add
Old Jun 12, 2008 | 02:43 PM
KingRanchMan02
Good for you!
RockWVU
Jun 7, 2013 05:21 PM
amtpdb1
2004 - 2008 F150
Aug 13, 2012 10:40 PM
pitmanr2003
May 12, 2009 05:08 PM
memphisfordguy
Jul 13, 2005 12:18 AM
dogbite32
Aerostar
Jul 25, 2001 10:31 AM
