Expedition lift and spring compressor?
Old Jun 30, 2010 | 05:50 PM
Gage2502's Avatar
Gage2502
Im going to lift the rear of my 2000 Expedition 4x4 2" and had a question...So I believe that you have to compress the springs in order to get the 2" spacers on. So wanted to know if these would work?
HEAVY DUTY COIL SPRING COMPRESSOR Strut Tool NR New - eBay (item 330445965832 end time Jul-01-10 12:55:31 PDT)
Thanks ~Gage~
Old Jun 30, 2010 | 06:34 PM
rews2's Avatar
rews2
That's the same type I used when I did my rears, got the tool at Harbor Freight.
I didn't pay real close attention to the first side and tightened down the bolts evenly and bent them a little but they worked fine for the other side.
Old Jun 30, 2010 | 09:39 PM
Big Greenie's Avatar
Big Greenie
Temporarily Deactivated
Just a word of advice. I bought 2" spring spacers for my Expy and ended up cutting them in half. Unless you have a plan to relocate the shock mounts, or can find longer shocks, I wouldn't do the 2" spacer. You end up right at the end of the shock travel.
These trucks have extremely limited suspension travel, without some extra work, spring spacers and lifting with the torsion bars just doesn't work out very well in my experience. As much as I do not care for them, a body lift might work better to get big tires under the truck. You can do 33's though, and with just an extra inch in back my truck sits nicely. It does away with the sagging butt look most Expys have.
Having a spring compressor really helps, they are pretty generic, most any one will work.
I have a pic of mine from our camping trip last weekend @ https://www.ford-trucks.com/forums/a...p?albumid=9362
jdmclemore
2004 - 2008 F150
26
Jan 18, 2013 09:37 PM
08whitetaco
Nov 27, 2012 10:08 AM
Icefan71
Mar 8, 2011 07:06 AM
banddr2
Nov 13, 2008 09:08 AM
aerocolorado
Aerostar
16
Feb 28, 2008 02:37 PM
