i just put a new autometer phantom boost gauge in my 97 and at about 18 lbs it goes haywire and the needle starts fluttering from 15 to 25. called autometer tech suppoort and they say its perfectly normal, sounds like bs to me, it is tapped into the map line. is this normal i had a issipro and glow shift gauge and put those in and they hold steady. thanks
You need to add a restrictor in the line, like an orfice. I bet that will help, it's helped other brands of boost gauges. The one I installed had one leg of the T almost totally blocked off except for the tiny hole, in the leg going to the gauge. Maybe epoxy that leg shut and drill a small hole and see if it helps.
Guys, this site is so great.... I just installed my gauges last night and was quite discouraged by the fluttering boost needle....today I got a new T, JB welded the end of it and then put a tip cleaning rod thru it for a tiny hole....voila! I'd say 95% improvement.... Goo enough until I put in my banks intercooler and can connect to the port on it.
Mines the opposite! Mine is smooth until like 10 or 15 then its starts to flutter a little bit! Same issue? Does it just need some restriction? The T that came with the boost gauge was TINY as it is tho. The gauge are autometers
