What is this plug??
Old Oct 28, 2011 | 01:13 PM
79OldBone's Avatar
79OldBone
What is this plug??
So the PO of my truck has a toggle switch going to a harness under the dash that use to plug into what looks to be like a dead end or something? But anyone have any clue whats going on here? Is this maybe a torque converter lockup switch???
Also my radio wiring doesnt have a constant 12v going to it on the green/yellow wire and NONE of the speakers work... I bought the adapter and I just jumped the memory and power wire to the 12 ignition wire to make it turn on but no music? Maybe this is for the radio?
Old Oct 29, 2011 | 12:13 AM
oldbird1965's Avatar
oldbird1965
I have no idea but this will give you a bump.
Old Oct 29, 2011 | 08:32 AM
bad12jr's Avatar
bad12jr
The one on the left looks almost like the door buzzer plug but hard to tell. The left looks like buzzer.
Just my guess though
Old Oct 29, 2011 | 09:09 AM
Blueheart's Avatar
Blueheart
X2 that's the door buzzer, he might have toggled it to silence the noise, I chucked mine within 2 days of buying the truck!
Old Oct 29, 2011 | 11:59 AM
richdawg's Avatar
richdawg
X-3, except mine was a very obnoxious ding, ding, ding, dingier. I'll take a look at the other plugs later this afternoon to see if I can identify them.
Old Oct 30, 2011 | 08:50 PM
79OldBone's Avatar
79OldBone
but the plug circled on the left doesnt go to anything.. its just a block that goes to nothing on the other side?
Old Oct 30, 2011 | 08:51 PM
bad12jr's Avatar
bad12jr
Defiantly the door buzzer then. Nothing to worry about on it.
Old Oct 31, 2011 | 12:27 AM
PstrokeN's Avatar
PstrokeN
with the speaker no music problem alot of the times i seen on my truck / alot of fords are the little square plug you buy they always never plug in tight and you wont have speakers when i got mine it only had two working so i just spliced em together and took that little square plug out hopefully this helps alot of times you can push hard and make it work
Old Oct 31, 2011 | 12:41 AM
Blueheart's Avatar
Blueheart
That black block is the buzzer, and the other is the connector that goes to it.
Old Oct 31, 2011 | 07:29 AM
79OldBone's Avatar
79OldBone
ohhh gotcha. Doesnt have anything to do with the dome light does it? I fixed the radio. The amp was bad under the dash, so I ran wires from the back of the sterio to the connector that went to the speakers from the other side of the amp.
Old Oct 31, 2011 | 09:02 AM
Blueheart's Avatar
Blueheart
[quote=79OldBone;10982338]ohhh gotcha. Doesnt have anything to do with the dome light does it? I fixed the radio. The amp was bad under the dash, so I ran wires from the back of the sterio to the connector that went to the speakers from the other side of the amp.[/quote No efffect on the dome light, mine still works fine.
jerryh20
Mar 10, 2020 03:18 PM
cekm2010
16
Mar 7, 2011 07:43 PM
dwrestle
2004 - 2008 F150
Dec 7, 2008 02:08 AM
Patatoe1
Feb 28, 2007 11:19 AM
