boost gauge flutter
Old Jun 29, 2010 | 11:31 PM
hedhntr's Avatar
hedhntr
boost gauge flutter
i just put a new autometer phantom boost gauge in my 97 and at about 18 lbs it goes haywire and the needle starts fluttering from 15 to 25. called autometer tech suppoort and they say its perfectly normal, sounds like bs to me, it is tapped into the map line. is this normal i had a issipro and glow shift gauge and put those in and they hold steady. thanks
Old Jun 29, 2010 | 11:48 PM
chicagodragon's Avatar
chicagodragon
mine des the same thing until it passes 20, then it evens out
Old Jun 30, 2010 | 02:11 PM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
You need to add a restrictor in the line, like an orfice. I bet that will help, it's helped other brands of boost gauges. The one I installed had one leg of the T almost totally blocked off except for the tiny hole, in the leg going to the gauge. Maybe epoxy that leg shut and drill a small hole and see if it helps.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Jun 30, 2010 | 02:14 PM
chicagodragon
do you think that would change the readings?
Old Jun 30, 2010 | 02:42 PM
Talyn's Avatar
Talyn
Pressure is pressure.
We are not looking for flow, but just a measure of the pressure. So as long as the pressure can transfer, it will go though the hole.
There is no place for the air to go, unless you have a leak, so as long as there is enough of a hole for the pressure to equalize, then it will work.
Old Oct 30, 2011 | 08:56 PM
savage250's Avatar
savage250
Thumbs up
Guys, this site is so great.... I just installed my gauges last night and was quite discouraged by the fluttering boost needle....today I got a new T, JB welded the end of it and then put a tip cleaning rod thru it for a tiny hole....voila! I'd say 95% improvement.... Goo enough until I put in my banks intercooler and can connect to the port on it.
Thanks for the help!
Old Oct 30, 2011 | 09:19 PM
79OldBone's Avatar
79OldBone
Mines the opposite! Mine is smooth until like 10 or 15 then its starts to flutter a little bit! Same issue? Does it just need some restriction? The T that came with the boost gauge was TINY as it is tho. The gauge are autometers
Old Oct 30, 2011 | 10:28 PM
savage250's Avatar
savage250
The flutter on mine was less at low boost then got worse as boost increased. The hole I put int the T was about 1/64th.
Still flutters a tiny bit around 15 psi.... I still have stock injector and tuning so I can't get above 18 psi yet.....until next week anyway
Old Oct 30, 2011 | 11:55 PM
94diF350's Avatar
94diF350
Oreillys has a sweet restrictor on the shelf for like 2 bucks where all the vacuum stuff is on the floor I bought one and it fixed al my symptoms
regidog
Mar 19, 2017 04:56 PM
Januch09
6.7L Power Stroke Diesel
Apr 29, 2016 04:56 PM
Planejet42
Apr 12, 2016 06:49 PM
Steelheader87
22
May 6, 2014 08:09 AM
hucka1a
Oct 23, 2005 11:11 PM
