P0683 - Glow Plug Control Module?
Old Jun 29, 2010 | 09:36 PM
Swingshiftworker's Avatar
Swingshiftworker
"Error Code P0683 - Generic - Glow Plug Control Module to PCM - Communication Circuit"
I've gotten this error code several times now and I don't think it's related to my DP Tuner, but don't know for sure. Does anyone have an idea what may be causing this code to be issued?
Old Jun 29, 2010 | 10:09 PM
PaysonPSD's Avatar
PaysonPSD
The GPCM (it is used in place of a GPR on Cali trucks and EXs) is going bad or gone. Easy to replace. Best price I have seen is at Riffraff Diesel. You won't need to get a new one until the weather turns so you've got time.
Old Jun 29, 2010 | 10:31 PM
Swingshiftworker
So, I've figured out that GPCM stands for Glow Plug Control Module.
I assume there's only one and I'm going to look for it, but it will help if you can give me a clue where to find it (a photo would be even better).
Also, I looked at the GPCM shown in the Riffraff Diesel link above and I don't see any others. Is it the one I should buy for my 2002 F250 7.3L Diesel?
Thanks!
Old Jun 29, 2010 | 10:53 PM
PaysonPSD's Avatar
PaysonPSD
There's only one GPCM on your truck and for your truck and the one at Riffraff is the one.
Here's a pic. Open the hood and look. You can't miss it. Only a couple of hold downs and two connectors.
It's plug and play.
Old Jun 29, 2010 | 11:46 PM
Swingshiftworker
Ordering the GPCM now. Many thanks, Payson!!
Old Jun 30, 2010 | 12:00 AM
PaysonPSD's Avatar
PaysonPSD
Glad I could help.
Old Jul 8, 2010 | 12:26 PM
Swingshiftworker
Ok, removed the old GPM and installed new one. Wasn't hard to install -- just awkward to get at because of the location and the air tube in the way -- but I got it done w/o dropping the nuts (which was the hardest part).
Was getting the same error code just about each time I started the truck recently. In fact, got one when I started the truck just before I installed the new GPM. So, hopefully, this will solve the problem. Will let you know. Thanks!
jayc3169
Jun 23, 2022 06:53 AM
Roody727
Jun 20, 2017 06:59 AM
HSaavedra
Mar 30, 2014 11:05 AM
Gruntface
Apr 7, 2012 12:03 PM
Gone in 60
Jul 8, 2009 10:18 AM
