tymar downpipe and cat delete
Old Jun 28, 2010 | 01:41 AM
mongo12's Avatar
mongo12
i want to get a tymar 3-4" downpipe for my 97 f250 and since the website is down how much do one of those cost. also i need to have a cat on the truck to fool the techs at the suck your wallet dry smog station. any one know where to find dummy cats cause i really don't want to spend 250 bucks at summit racing just to hollow it out and run it.
Old Jun 28, 2010 | 03:20 AM
Midwest Dually's Avatar
Midwest Dually
I think as far as the Cat thing, two options as for affordability.. One being to look at ebay, I have seen them there. Most places I see shy away from. The other being to hollow out a cat yourself, which isnt hard. You could probably pick up a pipe just slightly under the diameter of the hollowed out cat, set it into the cat, weld it in, and bolt it back up!
I played the game of dealing with emissions stations before.. I dont know what the laws are in Nevada, but cali was a PIA! I hope that helps a little!
Old Jun 28, 2010 | 05:43 AM
427 fordman's Avatar
427 fordman
IIRC the dp is about 130+ shipping
Old Jun 28, 2010 | 10:21 AM
Brown Falcon's Avatar
Brown Falcon
I'd say get the 3-3.5" downpipe, and then gut your stock cat and run a straight 3.5" pipe through it, then expand to a 4" exhaust after that.
3.5" is plenty big unless you are putting in some major upgrades.
Old Jun 28, 2010 | 03:26 PM
BadDogPSD's Avatar
BadDogPSD
Tymar does not have a working website, you need to call. Dale is a good guy and will help set you up right.
Brown Falcon has a good suggestion regarding the cat. I opted to go with a Magnaflow Hi-flow cat, but have not had a smog inspection since installing it. I kept the factory cat just in case I need it.
Old Jun 30, 2010 | 01:17 AM
mongo12's Avatar
mongo12
cool thanks for the tip about keeping it 3.5" i'll do that then run a 4" pipe right out the cat.
Jrob76
May 24, 2017 06:24 AM
-ZIXXER-
Oct 21, 2016 08:44 AM
JoeBoost
33
Oct 2, 2015 10:29 AM
tractoman
Aug 27, 2015 12:28 PM
J-W
19
Dec 31, 2010 07:45 AM
