460 overheating problems
Old Jun 28, 2010 | 01:09 AM
460-67-FORD's Avatar
460-67-FORD
01 POWERSTROKE
i just did a 460 swap from a 360 in my 67 f250 and im super confused my motor will run about 160 180 but my radiator will start smoking and just shooting out the overflow super hot!!!!!!!!!!! im lost please help my thermostat is 180 i have a 13lb cap on it im lost!!!!!!!! THANKS
Old Jun 28, 2010 | 01:34 AM
Ace.'s Avatar
Ace.
I would start with replacing the thermostat and go from there
Old Jun 28, 2010 | 07:43 AM
mark a.'s Avatar
mark a.
I would start first with what ace said. Are you sure there is no air in it ? If the Tstat checks out then I'd get a hold of a rad psi checker, pump it up and see if it holds psi.
Old Jun 28, 2010 | 08:03 AM
jim collins's Avatar
jim collins
I think it's air I had the same problem on a couple of vehicals until I got the air worked out.
Old Jun 28, 2010 | 08:23 AM
Fordby4's Avatar
Fordby4
Eliminate the thermostat for now and see how it runs, if it still does the same thing, you have a defective water pump or some kind of blockage in the system
Dan
Old Jun 28, 2010 | 09:15 AM
HIO Silver's Avatar
HIO Silver
Don't forget to open your heater valve while purging the system. Second, is the thermostat installed correctly? I've seen a few installed upside down.
Was the engine running OK before the swap?
Old Jun 28, 2010 | 10:40 AM
460-67-FORD
01 POWERSTROKE
thanks everyone i replaced thermostat and same thing its a brand new build yesterday was the first time i started it iv talked to some people and they say my 2 core radiator is to small?????????
Old Jun 28, 2010 | 05:54 PM
Ace.'s Avatar
Ace.
ouch, I'd say so
Old Jun 28, 2010 | 06:34 PM
evam350's Avatar
evam350
Try running it without the thermostat in, I agree with the other posters you definetly seem to have air trapped in the system.
Old Jun 28, 2010 | 06:36 PM
Poison Oil Racing's Avatar
Poison Oil Racing
well yea. The radiator is too small, you may have air in the system as well.
go get a 4 core radiator.
Old Jun 28, 2010 | 06:47 PM
Opossum's Avatar
Opossum
3 things, yes make sure there is no air under your thermostat, I do this by drilling a 1/8th hole in all my thermostats. Second, watch the coolant level in the radiator and rev the engine, if the pump is working usually the level will drop for a second. Third, I'm sorry to say but it really sounds like a bad/blown head gasket. The combustion pressure leaking into the coolant is flash boiling the coolant and pressurizing the system with combustion gasses which is why it is blowing out the raidiator so much and so hot. You can easily check for this with a chemical block tester, it tests for combustion gasses in the radiator, and is pretty darn cheep and easy for what it does.
Good luck, crossing my fingers.
Ohh ya, not that getting a 4 core radiator isn't a good thing or anything, you should get one anyway, but I doubt it's your problem, if it was your temp gauge(assumeing it works well) would rise.
Old Jun 28, 2010 | 06:52 PM
YouRang's Avatar
YouRang
good luck finding the radiator though i had to replace the radiator in my 460 last january finding the right size is a pain.
Old Jun 28, 2010 | 08:02 PM
78ford351m's Avatar
78ford351m
How nice of you to share where you got yours?
Old Jun 28, 2010 | 09:39 PM
Poison Oil Racing
Third, I'm sorry to say but it really sounds like a bad/blown head gasket. The combustion pressure leaking into the coolant is flash boiling the coolant and pressurizing the system with combustion gasses which is why it is blowing out the radiator so much and so hot.
Hadn't thought about that. good catch.
Old Jun 28, 2010 | 10:57 PM
460-67-FORD
01 POWERSTROKE
cool thanks im getting the new radiator tomorrow ill do all the other stuff people suggest thanks ill keep you all posted!!!!!!!!!
krecak
Aug 20, 2024 06:45 AM
Jmiller68
Jun 2, 2017 09:51 AM
Genadekw
May 12, 2016 02:57 PM
F350moneypit
Aug 18, 2013 01:50 PM
rickybobby1977
Jun 3, 2011 06:47 PM
