fuel pressure and boost ?????
Old Jun 27, 2010 | 11:05 PM
hedhntr's Avatar
hedhntr
Just installed a fuel pressure gauge on my 97. i put the sending unit in the schrader valve fitting on the fpr. im reading around 40 does this sound right? Also i put a autometer boost gauge in where it used to be a issipro but i did not change the line i just screwed the old fitting into the gauge and at about 15lbs the needle goes crazy from 15 to 20 lbs i guessing maybe the lines are not interchagable. any Ideas. Thanks
Old Jun 28, 2010 | 10:15 AM
Brown Falcon's Avatar
Brown Falcon
40 is pretty low. You should be running at least 60psi.
FPR shim would help bring that up to a better PSI for you.
Old Jun 28, 2010 | 10:46 AM
redone1's Avatar
redone1
Where's the best place to purchase a fuel pressure guage? I imaging NAPA would have it. Does it come with a schrader valve already?
Old Jun 28, 2010 | 11:00 AM
Brown Falcon
If you are hooking up to the FPR, you want a electric sending unit gauge. I'd order online.
Old Jun 28, 2010 | 12:50 PM
redone1's Avatar
redone1
Have a specific website brownie?
Old Jun 28, 2010 | 01:05 PM
Hussler's Avatar
Hussler
Here's one ... Fuel Pressure Gauge (Electric) w/sensor - Super Blue 52mm
Old Jun 28, 2010 | 01:20 PM
redone1's Avatar
redone1
Originally Posted by Hussler
Thanks Hussler. I guess I was expecting some non-mountable handheld guage. I'm not looking to mount this, just check the pressure to determine if it nees a shim or not. All of the ones I've found are like the one you linked to.
Old Jun 28, 2010 | 01:31 PM
Hussler's Avatar
Hussler
In that case just go to Napa and get a cheap fuel gauge, liquid filled is best but not require for occasional use. It will bounce a bit, just take the average of the high / low. Thought you were looking for cab mounted unit.
chicagodragon's Avatar
chicagodragon
stick type tire gauge
Old Jun 28, 2010 | 01:37 PM
redone1's Avatar
redone1
It would be nice to have a cab unit i guess. Would have to come up with an area to mount it.
Old Jun 28, 2010 | 02:02 PM
Brown Falcon
yep, tire gauge that goes up to at least 85psi
Old Jun 28, 2010 | 02:08 PM
redone1's Avatar
redone1
how many times will that tire guage work until it goes out? I guess it only needs to work 2 times. Maybe 3-4 if something goes wrong doing the shim.
Old Jun 28, 2010 | 02:17 PM
jchosler's Avatar
jchosler
That's what I use, I had to shim my FPR as well
Old Jun 28, 2010 | 08:08 PM
Brown Falcon
I used mine about 3 times. Then let it dry out really good and it still seems to work.
greenstar
Apr 2, 2014 06:04 AM
cabloom300
Jul 4, 2013 11:17 PM
JMP E350
16
Feb 28, 2013 10:05 AM
hedhntr
Oct 30, 2011 11:55 PM
bomexsaturn
Sep 2, 2007 04:45 AM
