bad power valve?
Old Jun 27, 2010 | 12:21 PM
460-f250's Avatar
460-f250
bad power valve?
hello i have a 87 f250,460, auto. (i know this the wrong area but there seems to be more carb people here.) stock carb.
my truck has had a backfiring problem since Ive had it and the exhaust pops lot when i let the truck coast.
but just in the last few days the exhaust has gotten really rich and my plugs are now black . also the idle is a little rough but not to bad .
but besides that the truck runs pretty good. does this sound like a bad power valve?
Old Jun 27, 2010 | 12:59 PM
Franklin2's Avatar
Franklin2
Yes, those are the symptoms of a bad power valve. A carb rebuild would take care of that plus freshen up the rest of the carb. The alcohol content in the fuel now is hard on the rubber parts of a carb.
Old Jun 27, 2010 | 01:18 PM
460-f250's Avatar
460-f250
ok thanks, does anyone know a site that i can figure out what carb i have? i want to make sure i get the right rebuild kit.
Old Jun 27, 2010 | 01:26 PM
Franklin2's Avatar
Franklin2
Just tell then what year truck and engine you have, and they will give you the correct kit. You have a Motorcraft made by Holley carb, and the kit will be for several of those year carbs. You will have parts left over when you are done since they cover several years. I have also heard some of these carbs had a dual stage power valve that is a little bit expensive, and some of the kits don't include that one in the kit.
Old Jun 27, 2010 | 02:06 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Standard Automotive Parts/ Hygrade kit # 1497B worked well for me.
This number should cross over as well...
Hope this helps.
Old Jun 27, 2010 | 05:44 PM
Old Hickory's Avatar
Old Hickory
It does sound like a power valve leak from what you describe. A good rebuild should
solve your problem. I would use either a Motorcraft or Holley kit to rebuild it. I have
found they are the best quality kits. The kits are pricey but the best quality.
Old Jun 30, 2010 | 10:40 PM
460-f250's Avatar
460-f250
well i got a rebuild kit but the power valve is different. the smaller one is the original. the bigger one is from the kit.
the other parts seem fine so did they redesign them? or is the carb from a different year?
Old Jun 30, 2010 | 11:37 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Edit: after going out to the garage and pulling an old 4180 off the shelf the one on the left of the first photo looks correct.
This is a 2 stage power valve, no?
Are the numbers the same?
What kit did you get? Genuine Holley or aftermarket knock off?
Old Jun 30, 2010 | 11:55 PM
460-f250's Avatar
460-f250
its a knock off, its all the store had and i have to get this done today.
the numbers on what?
Old Jul 1, 2010 | 12:23 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Is there no number indicating the set point of the valve?
do you know what your vacuum at idle was before you tore down the carb?
Old Jul 1, 2010 | 12:35 AM
82F100SWB's Avatar
82F100SWB
By the numbers, that is the proper carb for your truck.
I don't know holley carbs at all other than the one I had on my 460 liked dumping fuel on the intake and catching fire... So, your question about the power valve I can't answer unfortunatley. If that carb kit is the proper one for your truck, that power valve should interchange however.
Old Jul 1, 2010 | 04:49 AM
Old Hickory
The power valves pictured are both 2 stage units. It's what the 4180s came with. I
ended up putting a single stagle power valve in my 4180 because it worked better on
my modified 351W.
Old Jul 1, 2010 | 09:31 AM
460-f250's Avatar
460-f250
ok, thanks guys. im just finishing up and i will see if it runs any better. i did find that my floats were adjusted wrong, i was missing a check ball in the secondary diaphragm and my secondary throttle plates were seized up .
Old Jul 1, 2010 | 10:25 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Missing the check ball?
Sounds like someone was in there before you screwing around.
Let us know how you made out.
Old Jul 1, 2010 | 03:38 PM
460-f250's Avatar
460-f250
it runs great now, it idles smoother and finally no more backfiring.
pm042070
26
Jun 4, 2017 10:17 AM
DrZoom
Ford Truck Parts for Sale
Dec 23, 2015 05:12 PM
rockpile
15
Jul 18, 2011 11:23 PM
Smurf-Slayer
Jul 22, 2007 09:56 PM
poorfolks
Dec 20, 2005 10:41 AM
