DASH Pads
Old Feb 7, 2003 | 09:19 PM
mobleyt's Avatar
mobleyt
DASH Pads
What do you guys recommend for replacing, repairing a cracked up ugly dash pad. Looking for options other than $450.00 dollars for a new one, my wife wouldn't let me back in the house if I spent that on a dash pad!!!
Old Feb 7, 2003 | 10:17 PM
Andysutt's Avatar
Andysutt
DASH Pads
My truck doesn't have one.
Its took out and the holes filled and the metal dash is going to be painted the color of the truck
Old Feb 8, 2003 | 01:23 AM
merc460's Avatar
merc460
DASH Pads
I filled in the cracks on mine and then bought some very nice black viynl and glued it over the old one, it looks a lot better than the old one and only spend forty bucks. Eric
Old Feb 8, 2003 | 09:55 PM
Rosati's Avatar
Rosati
DASH Pads
I've thought about this in the past. I thought about gluing foam to the metal dash and then gluing material over that to create a different visual effect. It would take some ingenuity to blend with trim but easy enough. Just trim the foam about 1/4" away from the ents and put the vents on top to help hold the dash in. Then make a custom lower trim to tie the pad to the face of the dash. The OEM typr trim just pushes into holes drilled and would not be real secure unless you glued the edge of the trim to the dash as well.
GeneGregory
15
Oct 26, 2015 06:17 PM
Ripcity
Sep 30, 2013 07:36 PM
boos65
Jun 26, 2012 04:49 PM
sourpuss
17
Apr 8, 2006 08:28 PM
fordxxx
23
Mar 7, 2005 08:09 AM
