Front brake keeps seizing help!
"My problem is the brakes on the right front keep locking up!"
Gatta love the internet, your diagnosis is only as good as the description of the problem.
This is not a slam to the original poster,,but ya got to admit, on disk brakes, how can this happen? Drum brakes, one can understand it would be the adjustment to tight on the right, to loose on the left, but disk brakes? After the solution given, I'm confused.
When the brake pedal is pushed down with all parts working correctly, the pressure to both front calipers are equal. The front\rear presure is a diferent story. These hillbilly remidies given here are kicking my ****
I gatta know, with the parts the OP replaced and everthing working as the OP stated in the original post, how can a mis-adjusted flippin brake switch or Master Cylinder push rod cause only one side to lock up? You push to far on the pedal, for any reason, both front brakes drag, not just one, unless you have another problem. (yes, there is constant fluid presure to the calipers to cause a slight drag, but not enought to cause lock up as described) Sorry folks. I guess I have been doing this crap for to long and the older stuff is kicking my ****.
having been a Female Fleet Maintenance Mechanic and Operating Engineer for over 35 years, it has only happened to me once, so that should give you an idea of how rare this happens, the right front of most vehicles will always see more wear, tires wear more on the front right, because of a tighter turn radias, when turning right, the brakes get used a little harder on the right side too, why, I dont know, but the front right side disc pads are always worn more, maybe because hyd perssure will apply its self more to the line thats further away from the source, also a hyd. line will always burst, at the very end of a line, I could not belive that too, untill it was shown to me at a CNG training class, a metal line was twisted so it was a loop, hyd pressure was applied, and we were asked where the line would burst at, i said in the middle where the metal line seemed to be streched at, wrong, it bursted at the very end on the metal line, the right side caliper is the farther away from the MC than the left side, so its possible the R/S caliper being farther away from the MC was getting a little more pressure to it, because it was at the end farther away from the MC, Hydraulics are tricky,I have been working with Hyd. for over 35 years, and 25yrs on automated robotics, on sanitation trucks, and it still gives me a bad time, I know i will never ever know it all
Take Care and have fun, Chellie
I guess I'm one of those Redneck's you mentioned. I mean, there are two output's from your MC, one for the front, one for the rear. How the heck did that MC decide to put more presure on the passenger side than the drivers side coming out of one port? I have an understanding of fluid dynamic's, I'll let it go at that. I've been wrong before and will be wrong again
I wish I lived in "west, by god, Virgina"
