strange stalling problem
Old Jun 25, 2010 | 05:55 AM
Pete in Maine's Avatar
Pete in Maine
Greetings -- I've had a good run of trouble free driving and it's been a while since I've posted. Just learned of the Maine chapter and joined up -- anybody from here joined up there?
Here's my problem -- my truck seems to occasionally stall while I'm driving. At speed, the engine seems to jump right back, but if I'm stopped, it totally dies, then starts right up again. It seems to be very random (at least as far as I can tell). I'm pretty unskilled under the hood, but it seems electrical? Is this the CPS problem I've read about?
Help! And Thanks!
Old Jun 25, 2010 | 06:04 AM
427 fordman's Avatar
427 fordman
My guess would be the cps. Change it, you need a spare anyway, then you'll know if thats it.
Get one from the dealer or IH, not a parts store, better quality.
IH part#1876736C91
Ford#F4TZ-12K073-C
These are the dark gray ones a lot of us are using now. Did you have the cps recall done??
Old Jun 25, 2010 | 11:49 AM
Pete in Maine
Thanks for the thoughts. I did not do teh recall but I think it may have been done before my time. I'll do a search for the details on the install. Still a bit of a
Old Jun 25, 2010 | 12:06 PM
427 fordman
It's the sensor about the 10oclock position above the crank balancer that goes into the block. One 10mm bolt and it pops out with a little bar or something, may just pull out.
Old Jun 25, 2010 | 12:30 PM
DRRXR's Avatar
DRRXR
Last change of the oil?
Last change of the fuel filter?
How clean is the fuel bowl vent port located inside the bowl at the top at 3 o-clock?
Any debris in the bottom of the fuel bowl?
What is the fuel pressure at the shrader valve located just below the FPR?
Old Sep 8, 2010 | 10:29 AM
fnx4wheeler's Avatar
fnx4wheeler
I'm having the same problem. I just changed my fuel filter, oil level is in the hash marks, and I changed my CPS (2nd one) about a year ago <12K miles on CPS. Any ideas?
Old Sep 8, 2010 | 10:59 AM
Brown Falcon's Avatar
Brown Falcon
I have been through 3 CPS's in the last two years. It's pretty common for them to go out soon or even be bad from the start.
But the new dark grey ones, like posted above, seem to be working better and lasting longer. I keep a spare in my glovebox just in case...
Old Sep 8, 2010 | 09:22 PM
fnx4wheeler
The two I've replaced were purchased at the Ford Dealer. It was grey, is there a better CPS out there?
Old Sep 9, 2010 | 05:44 AM
427 fordman
The ones I listed above are the preferred ones to use now. They seem to be a little better...
Old Sep 9, 2010 | 07:16 PM
paddler's Avatar
paddler
PCM connector?
Your problem sounds similar to my loose chip problem... random stall, then comes back on if the truck has enough momentum to drive the engine.
May be worthwhile checking the PCM connections to see that they are clean and tight.
Old Sep 10, 2010 | 08:18 AM
DRRXR's Avatar
DRRXR
Post CPS answer
https://www.ford-trucks.com/forums/9...-this-one.html
Old Sep 10, 2010 | 03:02 PM
fnx4wheeler
Yeah, I thought about that. I wiggled the chip/pcm connection and the truck won't stall. The chip has been installed for several years. I'll keep it in mind but will probably start with another Ford CPS.
Old Sep 11, 2010 | 07:33 AM
Brown Falcon
Check the pins on the CPS plug as well. Could be bent.
