ive got three hours......
Old Jun 24, 2010 | 01:20 PM
93MARKIII's Avatar
93MARKIII
i rented a lift at buddies shop today at 5:30........i have major gas vapors, lol, enough to make your eyes water sometimes.......
what do i need to be looking for ? its 105 here today, i dont want to spend an hour aimlessly looking at stuff hoping to find a leak.....
seems to have gotten worse since the heat turned up a couple days ago...
i get it now on both fresh and max air.....
any ideas so i can mainstream the search ????????
i searched but couldnt really find anything that matched my situation
Old Jun 24, 2010 | 01:21 PM
93MARKIII's Avatar
93MARKIII
lol, rent is 1/2 case of beer and a bag of ice......of which i will drink probably half.....its good to have cheap dates for friends
Old Jun 24, 2010 | 01:44 PM
darthice's Avatar
darthice
maybe fuel injector o rings
Old Jun 24, 2010 | 02:01 PM
Country705's Avatar
Country705
same thing happend to me and it was the fuel injector o rings and a loose clamp on a fuel line.
Old Jun 24, 2010 | 02:05 PM
Conanski's Avatar
Conanski
Our Ranger sprang a leak a few weeks ago, turns out the filter had rusted through... easy fix.
Old Jun 24, 2010 | 02:07 PM
redlightning93's Avatar
redlightning93
Same things on my '85 EFI
Old Jun 24, 2010 | 02:22 PM
lew52's Avatar
lew52
Forget the leak , drink the beer !!! Are you getting fuel fumes , or exhaust fumes...
Old Jun 24, 2010 | 02:36 PM
danr1's Avatar
danr1
I'd pressurize the system via a jumper at the EEC test port, so you don't have to have it running, sit back drink a beer and wait and watch.
Its should become apparent fairly quick where the leak is, dripping directly on the floor, or puddling up on the motor, at least until the puddle overflows to the floor anyway.
Hard part sometimes yea finding it, easy part should be correcting it once you know what and where the problem is!
Old Jun 25, 2010 | 09:27 AM
93MARKIII's Avatar
93MARKIII
ok, so we didnt end up checking anything yesterday.....too damn hot and they had all three bays filled up......
stopped by just a few ago and my buddy jumps in the passenger seat and immediately says thats not gas.....thats refrigerant..... ok, these guys aren't AC techs by trade, so if he is right, where would it be leaking from to enter the cab like that ?
it never did smell like raw gas......always smelled more like old going bad gas....kinda that turpentine smell.....sound right to you guys ?
i topped it off with a can of juice with dye in it, but its too bright to see anything right now....bays still filled up.....any ideas where to start looking ?????
Old Jun 25, 2010 | 09:57 AM
jimjoebob99's Avatar
jimjoebob99
Did you check it with a refrigerant leak detector? Refrigerant is odorless and what you could be smelling is the PAG oil. A leak inside the cab would indicate the evaporator and if you have a UV light, you can't see it from the outside. You can, however, take the blower motor out to get a look at it. The condensate drain plug should weep your oil and dye out if that is the location of your leak. Also, if you have a good leak detector, check all the mechanical fittings.
Old Jun 25, 2010 | 10:30 AM
nstueve's Avatar
nstueve
turpentine smell is kinda what I had and it was a bad exhaust gasket... Leaked exhaust fumes into the engine bay which found their way to the cab... it was easy enough to figure out... wait till engine and exhaust are cool then start the truck and pour water around the exhaust fittings... if you see a bubbling you know you have a exhaust leak.
Have fun fixing that! they are a pain in the butt to replace!
Check all your exhaust for visable leaks and You can also do a quick check by plugging the tail pipe breifly (don't burn yourself) and that should push exhaust out the leak and make it easier to spot... 2 person job really so you do plug it to long...
If not check your other fuel items like fuel filter and fuel rails. RJM has a injector rebuild kit with all new o-rings and filter baskets if that is your problem...
Old Jun 25, 2010 | 10:48 AM
redlightning93
Those "Bandaids" may be coming back to haunt you on your a/c.
https://www.ford-trucks.com/forums/9...onversion.html
Mixing refigerants (r12 & r134) and oils that are not compatible along with sealers are sure to lead to an early system failure. I imagine you will need to take your system down and find you leak(s), make a proper repair, and do it right. A/C repair is not rocket science but if it is done properly the first time it will repay you with many years of service.
Old Jun 26, 2010 | 04:50 AM
93MARKIII's Avatar
93MARKIII
hahahaahaa.....damn.....can i get some ketchup to eat those words with
i think your right....oohh well, i was planning on replacing the compressor anyway due simply to age, looks like its time to bite the bullet and do it right.
i think my evaporator core is shot......drove around for 50 miles this evening with just the vent setting and NO SMELL!.....not even a hint! thunder storm came through earlier....temps dropped about 30 degrees so i took advantage of it....windows up/windows down/vent on high/floor/etc..... and no "gas" smell at all.....
Stephen Donovan
2004 - 2008 F150
Mar 8, 2013 08:13 AM
gillman.6
Jul 19, 2010 11:31 AM
420CREW
Jan 25, 2010 02:20 PM
nitro520
May 3, 2007 12:11 AM
hdbngr8
1997 - 2003 F150
Feb 8, 2006 11:59 AM
