Sponsored by: Real Truck
burning elictrical smell????????????
Old Jan 24, 2010 | 11:23 PM
420CREW's Avatar
420CREW
Exclamation burning elictrical smell????????????
Hello everyone I noticed the other day that there was a smell like a cooked wire after running the truck for about an hour. I looked everywhere and could not find anything. Today the same thing happened but after searching under neath the hood and under the truck, dash and I cant find anything? Has anyone experienced this or heard of this issue? Any ideas on where to look the smell seems to come form the front of the drivers side. I should note also that I never smell anything in the cab. Please help?
Old Jan 25, 2010 | 12:32 AM
ZBIGBIG19TH's Avatar
ZBIGBIG19TH
Check Cruise Control cut off switch under brake master cylinder.
There was a recall on it but I am not sure what years it concerned,it did mine 02.
Or check TSB on that .
good luck
Old Jan 25, 2010 | 07:10 AM
420CREW's Avatar
420CREW
Ok I will check that any other ideas?
Old Jan 25, 2010 | 08:54 AM
edjunior's Avatar
edjunior
Don't know what it is either. It has happened to me on numerous occassions. I can't pin it down to anything specific though. It's happened in winter with the heater on, summer with the AC on, with nothing but a vent, with and without cruise. Probably a handful of times in the 5 years I've had the truck. Everything still works, so I have no idea!
Old Jan 25, 2010 | 01:33 PM
aphotic26's Avatar
aphotic26
I had that recall done but never had any smells and it was leaking. I had a smell of burning electrical and it was my bulbs melting my headlights and caught fire took an hour then boom - check the bulb harness for any damage...just to be sure.
Old Jan 25, 2010 | 02:05 PM
420CREW's Avatar
420CREW
thanks for the heads up i replaced the headlight connectors last summer I checked them yesterday and they seem ok.
Old Jan 25, 2010 | 02:20 PM
jrjudd's Avatar
jrjudd
look closely around the exhaust. Lots of heat there. A heat shield or wiring restraint may have come loose.
Wayne242
Modular V8 (4.6L, 5.4L)
Aug 10, 2013 06:32 AM
rakar
1997 - 2003 F150
May 23, 2013 12:00 PM
xikar
Apr 15, 2011 05:37 PM
King7765
20
Mar 16, 2011 04:52 PM
Fordafied
20
Dec 4, 2005 01:13 PM
