Gears for towing
Old Jun 24, 2010 | 09:28 AM
jjarboe01's Avatar
jjarboe01
Gears for towing
So I have a 95 with the 300I6/mazda 5 speed combo. Anyone know what the stock gear ratio is in that, or how to identify it. I'm looking to go to 3.55's, or more preferably 3.73's. Is there a way to tell without pulling the cover off and counting teeth? Also, do I have to replace the pinion gear with the rest to change ratios?
Thanks guys!
Old Jun 24, 2010 | 10:32 AM
6CylBill's Avatar
6CylBill
You should have either 3.08 or 3.55.
If you tow often go to 4.10's and don't look back. With your 5 speed transmission the 4.10 gear won't hurt you so bad on the highway.
Old Jun 24, 2010 | 11:59 AM
94MustangGT's Avatar
94MustangGT
How much are you looking to tow?
Keep in mind the different ratio in the 5 speed compared to the automatics...
1st- 3.90
2nd- 2.25
3rd- 1.46
4th- 1.00
5th- 0.80
Compared to an AOD, for example:
2.40
1.47
1.00
0.67
Check the axle code on the door jamb, or crawl under the truck and read the tag on the rear axle. 3 08 would signify an open 3.08. 3L55 would signify a limited slip 3.55
I would think 3.55's would be enough to move most loads. Keeping the tire size near stock should keep some too.
Old Jun 24, 2010 | 12:21 PM
6CylBill's Avatar
6CylBill
94MustangGT, what do you think of 3.73's for the 5 speed?
The reason I also suggest lower gears with the manual transmission trucks is to help save the clutch.
Old Jun 24, 2010 | 02:04 PM
94MustangGT
^ I hear ya about the clutch. The deep 1st gear should help in that regard.
3.73's should work well, but personally I wouldn't swap out 3.55's for 3.73's. The slight increase in grunt wouldn't be worth the cost of the swap or the extra crusing RPM's to me.
Old Jun 24, 2010 | 07:38 PM
Rudedude1's Avatar
Rudedude1
3.73's are great hot rod gears for a street car. You get more off the line but don't loose much gas mileage and top end. In my opinion 3.73's are the best all around gear ratio unless you have a vehicle dedicated to towing like I do, for towing my travel trailer then I would say 4.10's.
Old Jun 25, 2010 | 04:40 AM
TexasGuy001's Avatar
TexasGuy001
Your truck probably has 2.73 or 3.08. Hopefully, it already has 3.55.
What size tires are on it. If they are stock I would go with 3.55-3.73 for the I6.
Old Jun 25, 2010 | 08:53 AM
Conanski's Avatar
Conanski
There is no "stock" gear ratio these trucks had a variety of gear options, look at the axle code on your drivers door pillar and then find it in this chart..
Ford Axle Code Chart .: Articles
For a truck with stock sized tires or close, an overdrive transmission, and the 300 I6, 3.55 gears will provide a good balance of pulling power and fuel milage, and yes you have to change the pinion gear when swapping ratios, the ring and pinion are a matched pair.
Old Jun 25, 2010 | 09:22 AM
6CylBill's Avatar
6CylBill
I agree with you guys that he shouldn't go lower than 3.73 and I agree he shouldn't bother with a swap to 3.73 if he has 3.55.. However, if this truck is the OP's dedicated towing rig, I think he should go the 4.10 route. Easier on the drive train and will help him get moving around town. Unloaded he will even see a fuel mileage increase around the backroads.
Now if this truck is just an occasional tow rig then I'm going with what everyone else is saying: Stock size tires and 3.55.
Old Jun 25, 2010 | 11:44 AM
Tegetus's Avatar
Tegetus
Totally agree....You can't beat 4.10's if hauling is the primary work that you do with the truck. On top of being better for your drivetrain, you motor with last longer due to the reduced stress being put on it and the higher rpms it will run.
Old Jun 25, 2010 | 11:54 AM
6CylBill's Avatar
6CylBill
Where did you come from? Welcome to the forums! I'll check out your truck.
The only thing is the higher RPM's are probably not good for engine life, BUT on the other side of the coin the engine is not being forced to work as hard. I would say higher RPM's on the highway are better than working the engine to death to get a load moving.
Old Jun 29, 2010 | 02:22 AM
TexasGuy001
I still think that the 4.10 gears are too much gear for the I6 with stock sized tires.
Old Jun 29, 2010 | 03:14 AM
86F150302's Avatar
86F150302
I agree
I would do 3.55s with stock tire size.
Old Jun 29, 2010 | 06:20 AM
6CylBill's Avatar
6CylBill
You guys are right, it is too much gear if you plan on driving on the highway much at all.
73BlackBeauty
20
Apr 14, 2012 06:30 AM
91dirtydiesel
Dec 19, 2008 01:39 AM
farmer ford
17
Apr 9, 2008 07:10 PM
sbeazel
2004 - 2008 F150
Oct 18, 2004 04:25 PM
smile5484
Nov 7, 2002 05:18 AM
