clutch beelding HELP
Jul 5, 2010 | 07:44 PM
okay so pumped the crap out of it and still nothing. I did it with the cap on and off, does it matter?
Jul 5, 2010 | 07:55 PM
can you prime the lines? Remove the line from the master cylinder and fill it with fluid.
Jul 5, 2010 | 08:09 PM
Quote:
Originally Posted by
oreocreaming
Ill try that, I know when I undid the screw on the slave cylinder fluid come out.
Jul 8, 2010 | 03:28 PM
okay so i got under the truck and and had the wife pump the clutch and every time she pumps it the lil hole on the slave cylinder facing the front of the truck bleeds fluid tried tightening it but still drips fluid so is the new slave cylinder bad?
Jul 9, 2010 | 01:48 AM
It should not be leaking anywhere, sounds like you may have gotten a bad one.
When you get a new one on it just get it to where you can get it in gear and drive it. A couple of miles will do more than the 70 pumps. lol
Jul 9, 2010 | 02:48 AM
Ya I'm getting a new one cause it just squirts all over. Ya I've done well over 70 pumps, atleast its not the master cylinder,lol
Jul 9, 2010 | 08:05 PM
*Up date*
Got it back on the road!!
Clutch is extremely close to the floor tho. Have to push it to the floor or it will grind?
Jul 9, 2010 | 09:35 PM
ford used a soft cast aluminum bracket around 90, it can wear out over time, i had to replace mine because the clutch wouldnt fully disengage after i changed out slave cylinder and m/c
Jul 9, 2010 | 10:17 PM
Jul 10, 2010 | 02:13 AM
Wow, That heim joint must be white gold ... A 3 dollar heim joint and a dollar bolt for 20 bucks !!
-Enjoy
fh : )_~
Jul 10, 2010 | 02:17 AM
You got it festus. There is a tech article on oil burners that uses the three dollar heim joint, probably where the guy on ebay got the idea. lol
hayden01
Apr 26, 2013 09:27 PM
CRUNKED77FORD
Apr 16, 2011 09:51 PM
sancochojoe
May 11, 2005 10:55 AM
Brimhall
May 28, 2003 11:18 PM
rayvin_
36
Mar 3, 2001 01:23 PM
1990 ,
73 ,
bleeding ,
clutch ,
diesel ,
f350 ,
fix ,
ford ,
heim ,
joint ,
pickup ,
tips ,
tricks
