A/C blows cold!
Old Jun 23, 2010 | 08:19 PM
rustyculley's Avatar
rustyculley
Bama, yours sounds like its doing what mine was doing exactly. It was noisy, so I knew the fan was running at high speed, but I had very little air flow from the vents. I did check under the glove box (you can see the fan if you get in the floorboard and look toward the firewall) just to make sure there was no plastic bag or something blocking airflow from that side. Let me know if I can help.
Old Jun 23, 2010 | 08:37 PM
bama29fan's Avatar
bama29fan
Originally Posted by SpringerPop
The fix for LESS air in MAX mode is to reach up under the instrument panel and remove the plastic baggie that got sucked up into the air inlet off the passenger's floor.
But you're right, it probably isn't the solution this time.....
Pop
LOL....that deserves a sticky!!!
Old Jun 23, 2010 | 08:39 PM
bama29fan's Avatar
bama29fan
i wont be able to tear in to it right away but when i do I might need some pointers....thanks
Old Jun 24, 2010 | 06:52 AM
Dirtfarmer69's Avatar
Dirtfarmer69
The only digital camera I have is my droid phone, but I can take pics if somebody can tell me how to get 'em on here. The process is easy.
Load the pictures up to tinypic.com. Once it is loaded up, a window will pop up giving you the location of the photo on the web, just copy that, and then click on the insert image icon (little yellow square with mountain) on FTE and paste it there. EZPZ. The pics will help folks.
Old Jun 24, 2010 | 11:42 AM
PSDLOVER's Avatar
PSDLOVER
Which kind of A/C stuff
I have the can of a/c stuff which says "134a". Is that the correct one? I am also going to look into the evaporator-Thx.
Old Jun 26, 2010 | 06:29 AM
rustyculley
134A is the original refrigerant in our trucks and that is what I have in mine. It works well enough that I haven't experimented with any other formulations. You can check out the evap core easily enough. Just make sure you have a good flashlight and a decent mirror. Good luck.
Old Jun 26, 2010 | 09:02 AM
mueckster's Avatar
mueckster
Pop
Back when I worked in an auto repair shop, a customer came in complaining of weak a/c. I reached under the dash an pulled out a potato chip bag from the recirc air intake. He was happy and mad at the same time. He said he was going to go home and whoop his kids' butts.
Pinzer
Oct 24, 2020 05:46 AM
slim813
Oct 13, 2016 08:28 AM
dman776
Jul 25, 2016 01:03 PM
Pikachu
20
Jul 22, 2015 08:18 PM
racer3022001
May 12, 2015 06:41 PM
