Gauge Readings
Old Jun 23, 2010 | 10:37 PM
twg1966's Avatar
twg1966
Trying to Gain Knowledge
Well then I might have to do that to see. I was thinking it would show something just idleing. I guess I didn't think it through all the way.
Old Jun 23, 2010 | 10:38 PM
ChunderDownUnder's Avatar
ChunderDownUnder
Originally Posted by twg1966
Well I hooked up my boost and pyrometer gauges this evening and the boost gauge does not register anything. The pyro is working fine. I disconnect the connection on the MAP line and get no movement one way or another at the open connection. I have 1/8 line running off of the 1/4 MAP line. I have checked the entire runn for kinks finding none. Sorry to post a long question on your post.
You have taken her for a run right???
Old Jun 23, 2010 | 10:49 PM
twg1966's Avatar
twg1966
I have now, it appears to be working correctly. Did notice the pyro went to 1200 when I put my foot into it. boost went to about 18. The pyro dropped back to about 800 almost immediately upon taking my foot out of the accelerator.
Old Jun 23, 2010 | 11:00 PM
bama29fan's Avatar
bama29fan
good deal...glad its working for you
Old Jun 23, 2010 | 11:07 PM
twg1966's Avatar
twg1966
I don't know what the heck I was thinking. I should have driven it first before posting such a dumb question/comment.
Old Jun 24, 2010 | 12:39 AM
twags6's Avatar
twags6
Originally Posted by Ponyboychris
I wonder if the Pyro is pre or post turbo. Not getting over 1000 degrees is suspect.
I was wondering the same. Plus if the tip of the probe isn't centered in the pipe, it can screw with the readings.
Old Jun 24, 2010 | 04:15 AM
ChunderDownUnder
Dont stress bro. I and many others have done the same. Thats why I asked
Old Jun 27, 2010 | 01:58 PM
deerslayer165's Avatar
deerslayer165
My pyro is in put with a clamp in the downpipe. I have no reason to believe its reading incorrectly
Old Jun 27, 2010 | 03:24 PM
farmb0y's Avatar
farmb0y
It's probably reading correctly, but add about 100-200* to know what the temps are coming out of the cylinders. Post-turbo pyro readings run cooler than when the pyro is mounted in the exhaust manifold.
Old Jun 27, 2010 | 09:04 PM
billyturbo's Avatar
billyturbo
I was gonna say!... My pyro is pre turbo. Mine hits 1000 degrees like nothing even in 80E. If I floor it in 140 aggressive it'll go up to 1400 sometimes. My max says 1490 . Which is pretty hot ,but from what I've gathered, Its not bad if it doesn't have time to heat up the components to that temperature. I think magnaflows are a little hotter since the muffler is huge?...
Old Jun 28, 2010 | 12:10 AM
deerslayer165
That makes sense, Ive just been told anything over 1200* is bad news.
Old Jun 28, 2010 | 04:26 PM
twags6's Avatar
twags6
IIRC, you wanna stay below 900 post turbo. If you're seeing 1200 post, you're running way too hot. The EGT's go down as they pass through the turbo, which is why most guys say add 100-300 degrees to your reading.
eunice-jean
Jun 27, 2022 11:57 PM
78 & 87 Super Cab
Jul 6, 2013 11:09 PM
mrad
Feb 3, 2010 09:24 PM
lighthousealarms
Jun 3, 2009 03:38 AM
jeko
Aug 3, 2002 12:42 AM
