I have a transmission temp gauge on the line going from the torque converter to the cooler. The temp usually runs between 165 and 180 when I am pulling my boat, (8,000 lbs), with an outside temp around 85. This past weekend it stayed around 195-205 the entire time I was puling the same boat. The temp outside was around 90. It has never stayed that high even in past summers with higher outside temps. I am always very careful to get the transmisson into torque lock up as quickly as possible to avoid excessive heat. Fluid level and smell is good. Is there possibly something going wrong in the transmission that would cause an increase in operating temps? It still shifts normal, no slipping or other obvious issues.
Thanks
Oops...sorry, I thought I saw you had an 05 V10...my mistake.... Just make sure you have a BIG tranny cooler in there. Do you have the trailer tow package or the camper package? Obviously, cooler is better.... occasionally hitting 200 prob won't hurt anything. Change fluid (twice as) often and don't allow it to STAY at 200 or above. Drop it down a gear if you have to...kick overdrive off.....
If it is in OD and can hold it, that it the best position for it. The TC is locked and the tranny runs cooler when locked.
Seems the OP has an 01 F250 with the 4R100. Sounds like he needs a cooler upgrade for starters. But that wouldn't explain why the sudden increase in operating temps, ambient temps non-withstanding.
I forgot to say it is a 2001 F-250 V10. The only upgrades I have made to the transmission was changing to synthetic fluid at 30,000 miles and a high capacity aluminum pan. It ran at normal temps the weekend before last on a 400 mile trip to the Lake of the Ozarks with the boat. It just started this problem this past weekend on a shorter trip. I did flush the radiator fluid a month ago, but like I said it was fine on the previous trip, so I do not think that is the problem.
I would second all the above, but would also recommend that you replace the fluid. Transmission fluid has thermal carriers to dissipate heat, my guess is the fluid is starting to break down and may not be carrying the heat properly.
I would also agree that 200 degrees running to the cooler is in fact normal. Just so long as the fluid is not getting over 240 on that same line you should be fine.
The time I had a problem with a high trans temp it was due to a problem with the filter. I never did find out just what did go bad. The problem did go away when I changed out the filter when I changed the overheated fluid.
