manual trans thread
Old Jun 23, 2010 | 02:02 PM
F-250 restorer's Avatar
F-250 restorer
Originally Posted by AbandonedBronco
The 300 needs a manual transmission. My Bronco 300 with a manual will leave behind my brother's Bronco 351 with a C6.
I've often thought about what it would be like to have a GV on the back of a manual trans. Unfortunately, the Bronco's are just too short for one (rear driveshaft is around 33" extended) so I can only dream.
AB-- If you had a GV on your rig, you'd be turning 2k rpm @ 100 mph! lol.
Old Jun 23, 2010 | 02:39 PM
AbandonedBronco's Avatar
AbandonedBronco
Lol, true. Just lullin' along, getting great gas mileage at 100.
That's with my current transmission though. If I was able to do a gear vendors, it'd allow me to have an easy swap of a T18/19 (no hydraulic clutch conversion) to get rid of my light duty aluminum transmission with a cast iron one. I'd still have an overdrive with it due to the GV, something those early cast iron transmissions don't. I'm always worried about my current one breaking while off-roading, but do too much highway driving to sacrifice OD.
Certainly don't need a GV with my current trans.
Old Jun 23, 2010 | 04:54 PM
AbandonedBronco
F-250, (and anyone else for that matter), if you'd like, I made a computer program that allows me to look at how transmission ratios, final drives, tire size, etc. affect engine RPMs and speed. It's pretty useful when seeing what a tranmission, gear swap, or tire size change would do to your engine.
PM me if you're interested.
Old Jun 23, 2010 | 09:35 PM
chrlsful's Avatar
chrlsful
swap of a T18/19
Or even a NP435
Hey, I'm too dumb to get the "computer program" to work.
Old Jun 23, 2010 | 10:02 PM
AbandonedBronco
Originally Posted by chrlsful
swap of a T18/19
Or even a NP435
That's just a picture of it.
Old Jun 24, 2010 | 12:38 AM
F-250 restorer
AB--
Thanks for the offer. I'd love to give it a whirl. I'll PM you soon.
Old Jun 24, 2010 | 06:56 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Chad: Here is one for you to play with Gear Ratio Calculator
Old Jun 24, 2010 | 07:36 AM
6CylBill's Avatar
6CylBill
A manual tranny makes a big diference. I've been experimenting with my automatic transmission by manually shifting it (up and even down, when needed). The truck drives so much stronger.
I imagne a manual transmission behind the 300 would make a world of difference.
Old Jun 24, 2010 | 07:55 AM
F-250 restorer
What really started to make me wonder about my c6 was when Harte3 mentioned that he has no problem getting up to 70 mph going up the on ramp.
I am hesitant though, because the ZF 5, which sounds like the best trans so far, has three gears that I would be using--without granny first and OD. That is just like my C6. But I need to compare the gears.
What really makes me sit up and take notice is the thought of installing my Gear Vendor with the ZF, giving me double the amount of forward gears, and double OD. Whow, an automatic-manual hybrid trans.
Old Jun 24, 2010 | 08:03 AM
AbandonedBronco
The biggest issue you're dealing with with the C6 vs, say, a ZF-5 is simply that the C6 is an automatic. It takes a lot of horsepower drain to run the pump to really get the C6 going under load. I've heard upwards of a 40 horsepower drain just for the engine to turn the C6 over. With the manual, it's a direct 1:1 link, so that loss is significantly less.
Old Jun 24, 2010 | 08:38 AM
6CylBill's Avatar
6CylBill
Justin (AbandondedBronco) makes a valid point, Mr. Kevin. You release a lot of ponies with the manual transmission as opposed to the automatic. Not only do you retain 20 or more horse, you also command the transmission - which as I've been learning makes more than a large impact on power.
Old Jun 24, 2010 | 08:42 AM
texasyeti's Avatar
texasyeti
Not to hijack or anything but I have a T-19 I am going to rebuild and put behind a 300 in my 64. I have been wondering about the clutch.
F250Restorer - are you planning to try and recreate the factory clutch set up for the manual shift or go with a cable? Or even a hydraulic?
Old Jun 24, 2010 | 08:43 AM
  #28
jas88's Avatar
jas88
It depends on the engine's power band to some extent, I guess. When my Bronco had it's original 302/E4OD and I also owned a '90 F150 with 302/M5R2 (both had 3.55 gears), the Bronco was quicker and got better gas mileage. So the 302 didn't mind the auto. But my current 300 did not like it's original E4OD at all.
Old Jun 24, 2010 | 08:48 AM
  #29
6CylBill's Avatar
6CylBill
That is very interesting, Jas88.
Old Jun 24, 2010 | 10:44 AM
  #30
AbandonedBronco
I think you're right, and that'd make sense when you look at where the 300 makes it's power. At peak torque (for a stock carb model), when it's putting out the most strength (and when the C6 is probably sucking up the most horsepower) is at 255tq @ 1400 RPMs.
Horsepower = (Torque * RPM) / 5252
Horsepower = (255 * 1400) / 5252
HP = 67.97
So at 1400 RPMs when it's making it's most torque, the engine's only making 68 horsepower! An EFI 300 (260tq @ 2000 RPM) is still only making 99. If during that peak strength an auto is sapping upwards of 40 horsepower, that doesn't leave much horsepower left to get the vehicle moving... On a carb model, that could be like 25 - 40hp left going to the wheels.
A 302 (at least EFI), makes 270tq @ 2400 RPMs. 123 horsepower left during it's peak torque. A little bit extra for that auto transmission to pull from, so maybe it doesn't care nearly as much.
The 300 just doesn't have enough hp at it's peak torque left over to be giving it up to an automatic.
