Battery voltage
Old Jun 21, 2010 | 09:24 PM
raycan's Avatar
raycan
Question Battery voltage
I posted earlier about multiple error codes and keyless entry issues leading up to stumbling and my 2000 4.0 SOHC ltd. running like a sick dog. Before I start chasing the usual suspects would low battery voltage cause these issues? I am going to do a load test in the a.m. It did'nt cross my mind because the battery is 1 yr. old but the day it started it was 100 degs. and heat is worse on them than cold weather. Thank you for time.
Old Jun 21, 2010 | 10:47 PM
steve(ill)'s Avatar
steve(ill)
yes, if you have a low battery, you will have multiple computer problems and run like "a sick dog". was your battery low ? Normally if the starter will crank, you have adequate voltage. If you get down to 9-10 volts, funny things start to happen.
Old Jun 22, 2010 | 12:18 AM
aquanaut20's Avatar
aquanaut20
I believe the first thing I suggested you check on your last post was the battery connections. Yes, it is common for ghost codes to register with low battery power
Disconnect the battery for 1/2 hr to clear all learned info, not just code clearing.
Wait until they come back, check battery connection and main harness from engine to chassis.
Clean MAF...
Old Jun 22, 2010 | 08:17 PM
raycan's Avatar
raycan
Aquanaut20 I cleaned the cables and post two days ago and the door lock and keyless entry problems stopped. I was not able to work on it today. I will post on here what I do find tomorrow. Thanks again.
Old Jun 23, 2010 | 12:44 AM
aquanaut20's Avatar
aquanaut20
Now that you have reset the tables on the PCM, run the truck and see if the codes return... Then get back to us...
Old Jun 25, 2010 | 08:23 PM
raycan's Avatar
raycan
Sorry for the late update...102 degs. + kids. I cleaned MAF,throttle body checked for obvious vacuum leaks and didn't find any hoses cracked and cleared codes. Still missing when I get on the accelerator hard. Drove up the road a mile or so and would barely pull a small grade(I know this was not far enough for pcm to learn fuel trims) coming back to friends shop I matted it and ran like a banshee? cut off and refired 2 mins. later and it started loading up and missing again. I am going to put a fuel filter on Sat. and see what happens. cel on again. Voltage checked out at 12.6 volts on battery.
jacaroo
Jun 5, 2013 06:44 PM
cak301
Jul 23, 2011 12:33 AM
89Bulldog
1983 - 2012 Ranger & B-Series
Jul 28, 2010 09:01 PM
RedLesPaul
Aug 29, 2007 10:47 AM
mmhud
Jul 19, 2004 08:48 PM
