HPOP Fitting should I replace
Old Jun 23, 2010 | 09:58 PM
  #31
m-chan68's Avatar
m-chan68
Updated_High_Pressure_Oil_Pump_Cover_For_03_6_0L picture by m-chan68 - Photobucket
This is the under side of an original '03 high pressure oil pump cover.
And here is the under side of the replacement cover.
And here is the discharge tube. The shiny area in the photo is where it tends to rub through under the cover.
Old Jun 23, 2010 | 10:01 PM
  #32
cheezit's Avatar
cheezit
cool, thank you.
also note the location of the silicon on the pump cover gasket. that I was refering to.
Old Jun 24, 2010 | 08:33 AM
  #33
w_huisman's Avatar
w_huisman
delete please
Old Jun 24, 2010 | 08:37 AM
  #34
w_huisman's Avatar
w_huisman
delete please
Old Jun 24, 2010 | 08:53 AM
  #35
florida_1959's Avatar
florida_1959
Got my oil cooler kit, updated supply and drain pipes yesterday. Not associated with, but excellent service and pricing from Gene at Tousley Ford. Only thing I wasnt aware of is the screen also comes in the oil cooler kit, so now I have two screens. Just need BPD's EGR cooler to arrive and I will begin the job. Hopefully able to take lots of pictures along the way. I am certain to have questions as I go, I appreciate all the great info and tips on here.
Old Jun 24, 2010 | 12:09 PM
  #36
04scurs's Avatar
04scurs
Thanks again m-chan68,
I looked at a new one with the groove on the inside, and on the outside it has a raised contour that follows the goove on the inside. Would this raised contour only be on the new covers that have the goove on the inside? The reason I ask is the outside of the new cover looks exactly like the one that is currently on my motor and the part numbers are the same.
there was some warranty work done on my truck for the ICP and some surging issues in the last two years.
Thanks again.
Old Jun 24, 2010 | 02:32 PM
  #37
florida_1959
Does anyone know if the STC fitting upgrade is available anywhere besides Bullet Proof Diesel?
Old Jun 24, 2010 | 08:15 PM
  #38
MudhenGIB's Avatar
MudhenGIB
Apologize for the ignorance, there are multiple conversations going on in this thread. For my '05 SD, even if I purchased the kit from BPD for the HPOP fitting (the one previously referenced), I still should purchase Ford part 3C3Z-9G805-AA?
Thanks.
Old Jun 24, 2010 | 08:50 PM
  #39
m-chan68's Avatar
m-chan68
Thanks.
No, that part is specific, exclusively to 2003 model year engines.
Old Jun 24, 2010 | 08:51 PM
  #40
MudhenGIB's Avatar
MudhenGIB
Thanks. So what I need I have. I appreciate your time.
Old Jun 24, 2010 | 08:55 PM
  #41
m-chan68's Avatar
m-chan68
Just the STC fitting replacement kit part number 4C3Z-9B246-F.
Old Jun 25, 2010 | 06:41 AM
  #42
npccpartsman's Avatar
npccpartsman
Would you post the part #'s of the upgraded turbo supply and drain lines please?
Old Jun 25, 2010 | 10:41 AM
  #43
Fallguy2004's Avatar
Fallguy2004
I would say you got a freebie on the screen, my oil cooler "kit" did not come with one.
Part # I have on the turbo oil drain is 6C3Z*9T515*A, if that partially helps ya.
Old Jun 25, 2010 | 10:46 AM
  #44
npccpartsman
I got updated Ford and IH part numbers for the turbo pipes, screens and pump covers and posted them in this thread: https://www.ford-trucks.com/forums/8...on-part-s.html
Old Jun 25, 2010 | 06:25 PM
  #45
MudhenGIB's Avatar
MudhenGIB
I have 4C3Z-9B246-E
What's the difference between E and F???
Thanks.
