Installing new performance exhaust
Old Jun 21, 2010 | 02:57 PM
mint350's Avatar
mint350
About to order some performance header, high flow cat, muffler and pipe assembly and throttle body spacer. Ive always done my own minor repairs to my trucks. Like breaks, suspension. Is there anything i should be aware of before removing old parts. Especially the old headers??
Thanks a lot!
Old Jun 21, 2010 | 03:13 PM
CS45's Avatar
CS45
Just had this done. At a bare minimum you should have a oxy/acetylene torch, drill bits and easy-outs handy...................
Good Luck.
CS45
Old Jun 21, 2010 | 07:33 PM
86F150302's Avatar
86F150302
Dont waste your money on a TB spacer.
Use that money you save from the spacer and to do a good tune up. That way you will actually gain something.
FullSizeBronco.com - 78 - 96 Ford Bronco offroad club, forums, tech, installs
Soak header bolts for a few weeks.
Old Jun 22, 2010 | 02:01 PM
broozerthehoundog's Avatar
broozerthehoundog
I just removed my stock exhaust manifolds 100,000+ spun right out.
Spray some pb blaster on it for a few days before you start.
On the day you remove old exhaust, start truck for about 2 minutes and shut off ,then loosen all exhaust manifold bolts while engine block is semi warm and bolts are cold.
Work fast to crack them loose before heat transfers to bolts.
This method usually prevents any broken bolts.
Old Jun 22, 2010 | 06:55 PM
TexasGuy001's Avatar
TexasGuy001
Yeah, TB spacer is a waste of $.
I would soad the header bolts multiple times for at least a week. Even if you do that you still might break one off.
Old Jun 22, 2010 | 07:33 PM
khadma's Avatar
khadma
Carpenter Local 745
My headers came with a new engine.
I went with JBA shortie stainless steel units. I kept the stock cats, but I am in the market for some high flow units. A 40 series Flowmaster finishes off the exhaust.
All the O2 sensors were kept.
I agree, soak the manifold bolts for a few days.
Old Jun 22, 2010 | 09:41 PM
BRay09's Avatar
BRay09
Like said above, TB spacers are a waste. I agree to soak all your bolts for at least a week with PB and do the 2-3 minute engine on time.
Just some advice on the exhaust... Spend the extra money for the JBA stainless steel headers. Painted from summit doesn't last very long. Mine did for about 3 years in great Norther Ohio weather. After that they started leaking at the welds. The JBA has a thicker flange and better hardware with locking washers so they won't keep backing out on you. Finish the exhaust with a high flow cat and your choice of a free flowing muffler. a 3" single will do the motor some good.
I wouldn't try wasting your time with the studs connecting the manifolds to the old Y pipe. Just cut em. They probably will break off anyways...
Old Jun 22, 2010 | 09:59 PM
khadma's Avatar
khadma
Carpenter Local 745
My JBA shorties came with new hardware to mount to the y-pipe.
Like mentioned above, it is worth the extra money.
cuellar23
Apr 2, 2013 07:09 AM
NjOffRoaderX
3.8 & 4.2L V6
Jun 24, 2011 11:58 PM
mtt_e
Exhaust Systems
May 3, 2005 04:25 PM
fyrrmann
Nov 30, 2004 11:36 PM
toughf1
Exhaust Systems
Mar 22, 2001 12:50 PM
