6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Removed my dpf
Old Jun 25, 2010 | 03:53 PM
  #31
StanleyZ's Avatar
StanleyZ
You know maybe there is another way. Over on another thread there is discussion about an over/under drive from gear vendor. seems to me that would make the truck more like the 2011s, they went to a 6 speed automatic and use only 373 and above diffs. I'm trying to look into it but the first hurdle was that the cost was $2900, second hurdle was that on the web site they didn't list an application for a 430 diff, but I'm thinking there has to be one. I can't see where Ford would be upset with using that, but ya never know. And of course you would have to keep the truck a looooooonnnnnggg time to get your money back at that price. Just an idea.
Old Jun 26, 2010 | 07:18 AM
  #32
marspec's Avatar
marspec
Originally Posted by LaxPlaya21
So because it's a 6.4, the motor will blow? You would think someone who is a posting 'Guru' like yourself, would have something a little more informative to add to this convo than what some random troll might say from a chevy/dodge forum.
Either way thanks for your input, it was extremely helpful.
Also I have 30K miles on my truck in one year tuned running a 275hp tune and it has been flawless.
I think he was referring to the $15,000 engine replacement, not mileage.
Old Jun 27, 2010 | 12:46 AM
  #33
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Originally Posted by ford-speed
you can remove the DPF but I highly and strongly advise of not to do it.Your DPF is a diesel particulate filter,and when we remove the dpf we usually use a filter jack to lower it down, it is very fragile and very expensive.
Wow are you kidding me????
Old Jun 27, 2010 | 09:34 PM
  #34
bigsteve1969's Avatar
bigsteve1969
nope im not a troll from a dodge or chevy forum. im a ford mechanic that deals with 35k 50k mile engine failures every day. im just tryin to give yal the truth. a dealer can flag your vin and you not even know it. when ford warranty or esp prior approval looks at it... automatically denied. i dont agree with emissions bull **** either but at the rate these 6.4s are dropping i wouldnt do anything to void my warranty. hope you have good luck out of your truck
Old Jun 27, 2010 | 09:37 PM
  #35
bigsteve1969
Originally Posted by ruschejj
But, to the 15,000 mile failure guy, I've got 149,800 right now and I'll run that thing at 220 degrees for 10 hours any day and every day I have to. Truck has made us a lot of money.
$15,000 engine replacement should have been more clear.
Old Jun 28, 2010 | 12:01 AM
  #36
Neil64's Avatar
Neil64
6.4 Engine Failures
BigSteve1969,
Can you tell us what you are seeing out of the 6.4 - good and bad? Also, as for the 6.4 engine failures, can you tell us what fails and what the root cause of failure is?
What preventative maintenance or mods would you recommend to enhance the 6.4 from any perspective?
As for Ford flagging a VIN can you share any info you have on why and how Ford reached the conclusion that a warranty is voided?
Thanks...
Old Jun 28, 2010 | 12:11 AM
  #37
LaxPlaya21's Avatar
LaxPlaya21
Sorry for jumpin on ya. I tend to get a little worked up late at night haha. I can get defensive of the forum if I feel like people are not trying to be helpful, and I feel they are degrading the value of it. Sorry for the confusion.
It really is amazing that you guys see so many engine failures. I have 30K miles on mine without a single issue. I am tuned, and I take on that responsibility if I have an issue... I would never try to trick a dealership by lying to them.
So how would you compare the 6.0 to the 6.4? Everyone I know with a 6.0 have had major problems including myself. I also know many people with the 6.4 and not one of them have a single issue with their trucks. What do you feel are the weak points, and what are the culprits behind the engine failures?
Old Jun 28, 2010 | 09:19 PM
  #38
bigsteve1969
Originally Posted by Neil64
BigSteve1969,
Thanks...
alright i hardly see the good i mean by the time it gets to us its got trouble so when i talk about engine troubles its something i see week after week. i think most issues stem from the high pressure fuel system. it ether goes out at the pump and tears threw the whole fuel system. or the injector drools and burns the pistons up.
keep your svc up to date and keep all reciepts. dont run offroad fuel cause ford warr. does call for fuel samples. usually if the truck needs a new engine ford sends out a inspector to take pictures of everything.
ford just declines or they dont thats up to them they look at previous svc records and things found while worked on.
main thing is if you wanna stay under warranty have everything done doccumented. if you dont care bout warranty, make sure the gains are worth the cost both now and later.
Old Jun 28, 2010 | 10:46 PM
  #39
Grunnsetning's Avatar
Grunnsetning
The weakest point seems to be the head gaskets but at 300+ HP tunes.
Old Aug 15, 2010 | 12:39 AM
  #40
AlbyVA's Avatar
AlbyVA
Big Steve:
I've been reading your posts and I don't seem to make the connection,
so maybe you can help me understand something.
The DPF's purpose is to deal with exhaust emissions, right? So how would
the removal of the DPF impact the Engine and/or Fuel System? Even if the
DPF voids your warranty, its removal should not be the cause of a
catastrophic engine failure, right?
Old Aug 15, 2010 | 06:47 AM
  #41
capt caper's Avatar
capt caper
See these YouTube videos of the 6.4 and the problems from DPF,etc.
YouTube - 6.4 TEARDOWN 1 OF 3
Old Aug 15, 2010 | 11:42 AM
  #42
AlbyVA's Avatar
AlbyVA
Thanks for the video. Overall, the gist of the video would suggest that
doing a DPF Delete is a Good Idea, but you'll have to accept the fact that
if you have engine or fuel problems, you might as well dig into your piggy
bank, because Ford's gonna tell you to blow smoke.
Old Aug 15, 2010 | 12:00 PM
  #43
Johnny Langton's Avatar
Johnny Langton
Originally Posted by Brandon D
they can flag my VIN # in Ford's system and every dealership after that would know about it.
This is EXACTLY what will happen.
JL
Old Aug 15, 2010 | 12:09 PM
  #44
AlbyVA's Avatar
AlbyVA
JL
Here is an interesting question... What about 3rd Party Warranty Policies?
If you get a Warranty, does Ford flagging my VIN matter? I'll just take my
truck to the Acme Diesel repair shop down the road and get whatever issue
resolved while having a DPF Delete installed, Ford's flagging doesn't mean squat.
Eventually all warranties run out, so in the end, one day you'll have to pay out of
pocket for something or another.
Old Aug 15, 2010 | 12:18 PM
  #45
Johnny Langton
Oh yeah,those warranties....the ones that will do any and everything they can to avoid paying for any kind of claim....you'll probably be just as successful as the next guy that didn't modify his federally mandated emissions equipment, or maybe not.
I guess the $2000-up questions is this...can you afford the repairs, or worst case, an engine replacement out of your pocket in one hit? That's what one must ask themselves.
JL
