Hi guys,
I finally got my truck from texas and drove it 1600 miles home to mn. It is a 06, 4x4 with a 5.4, 100000 and xlt. I have some issues.
Check engine light
How do I fix these?
Code p2272
2/2 signal stuck lean
Code p0161
Heater ckt malfunction
Abs Light
Ok I have the abs light come on after start up. How do I distinguish what sensor it is? I have had the truck all of a sudden have the tow/haul mode blink and the speedo not work. I am thinking it is the sensor in the rear diff but I don't know how to diagnosis.
Check gauges
This comes on once in a while and the temp gauge is pegged. I freaked out the first time but realized that if I with my scanner that the temp is 204-215 at the highest. As soon as I shut off the key and restart it is in the normal range where it belongs.
Sorry about the long post, should i seperate these issues?
Thanks for all the help!!!!
All the fluids and filters are being changed as we speak!!!!!
I found out my issue, I was thinking that 2/2 was the passanger side and it is the drivers side!!!!! It was unhooked!!!!!!! One thing on the list down!!!!!!
I think my rear brakes where setting of my vss. So thats another one down on the list. I still have the check gauges!!! Can anyone fill me in on this one???
Check out the F150 threads. There are some 5.4 GODS on there. Same engine, so it's just a thought. I was thinking someone left a tune on your truck until you said the 02 sensor was unhooked.
