po713
Old Sep 21, 2011 | 08:45 PM
MANNY RUIZ's Avatar
MANNY RUIZ
po713
How do I fix this code po713 transmission fluid temperature sensor circuit
high input? My truck shifts fine light are out until it starts to warm up then the
tow haul light flashes abs come on temp gauge goes wild.
my truck is a 2004 super duty 4x4 6.0
Old Sep 22, 2011 | 12:05 AM
jimmyb08SD's Avatar
jimmyb08SD
Is it only the electronics going goofy, or is the truck acting up as well? How does it drive while all of this is going on?
Old Sep 22, 2011 | 06:51 AM
Unrealo4's Avatar
Unrealo4
At the top of this forum there's a tech folder. Inside about 1/3rd of the way down there is a writeup i made to help people do this.
Old Sep 22, 2011 | 10:45 PM
jimmyb08SD's Avatar
jimmyb08SD
Whats it called I see nothing on po713?
Old Sep 22, 2011 | 10:53 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
It is in the tech folder in the Torqueshift transmission section:
https://www.ford-trucks.com/forums/1...l#post10075886
""""""TorqShift P0713 TFT Sensor Failure Replacement Procedure
Thanks, Unrealo4"""""""""""""
Old Sep 22, 2011 | 10:58 PM
BLADE35's Avatar
BLADE35
P0713 Transmission Fluid Temperature Sensor "A" Circuit High G^ g g T* D* d d M* U TFT
you need a new tranny fluid temp sensor
Old Sep 25, 2011 | 04:04 PM
MANNY RUIZ's Avatar
MANNY RUIZ
It runs fine and shifts good.
Old Sep 25, 2011 | 04:35 PM
MANNY RUIZ's Avatar
MANNY RUIZ
It seems to run fine and shift ok.
Old Jan 9, 2013 | 10:36 PM
Vic Collins's Avatar
Vic Collins
1996ford bronco defeat code po713 please
s_herod
Nov 14, 2024 03:39 PM
Shiloh51933
Oct 26, 2016 08:52 AM
Rod Jr.
Nov 17, 2010 06:08 PM
attak44
Oct 4, 2010 11:15 PM
04HD
Sep 12, 2010 01:10 PM
