temperature rising
Old Jun 18, 2010 | 11:12 AM
MMSGuthrie110's Avatar
MMSGuthrie110
temperature rising
96 F150 4.9l, About a week ago i was pulling a trailer with my truck and it just about overheated because the trailer was too big. there was coolant spewing out of the overflow and temperature was way up. I let it cool down and put coolant in and stopped pulling the trailer. I have been driving it like normal for the past week and it drives fine but the temperature will go up a bit higher than it used too. i even switched to a 160 therm. from a 195. and it will still rise a little higher than i like. It drives fine though. I was just wondering what i might have messed up. thanks
Old Jun 18, 2010 | 12:48 PM
Duke of Nada's Avatar
Duke of Nada
How big was the trailer?
Old Jun 18, 2010 | 12:52 PM
MEDF150's Avatar
MEDF150
I'd question putting a 160 degree thermostat as it will probably affect the computer control of the fuel system. It will believe the vehicle is still in the warming up state as it expects to see 195 degrees. You'll be running richer than you should be.
Old Jun 18, 2010 | 01:42 PM
Duke of Nada
The lower thermostat wouldn't cause it to run hotter, but your right he should put the temp that it calls for back in. I went through a similar thing with my truck. Here is the forum https://www.ford-trucks.com/forums/9...ml#post8965854.
Old Jun 18, 2010 | 02:02 PM
mprice's Avatar
mprice
Does the fan still spin like it should? When cold - and the engine OFF of course - it should move by hand but stiffly and it should not spin freely by itself at all.
Old Jun 18, 2010 | 04:05 PM
lew52's Avatar
lew52
Put a pressure tester on it to see if you have any leaks , check the fan clutch & radiator cap , you should have at least a 180 thermostate ....Lew
john19999
Nov 21, 2010 08:26 AM
hi-jacker
Jul 13, 2010 10:05 PM
krankshaft
Aerostar
16
Oct 4, 2008 07:09 PM
truckfreak69
20
Mar 9, 2003 04:31 PM
cchev
1978 - 1996 Big Bronco
Jan 15, 2003 05:39 PM
