Need help Please!! Fuel Filter Replace!!
Old Jun 17, 2010 | 06:29 PM
ruff08's Avatar
ruff08
Exclamation Need help Please!! Fuel Filter Replace!!
I bought tool and can't seem to get filter off any idea's are solutions? Thanks for any help!!! Nothing quick about this disconnect!!! 1996 F-150 gas
Old Jun 17, 2010 | 06:49 PM
White 97 xlt's Avatar
White 97 xlt
Push in on the line as you wiggle the tool in, that should help....
Old Jun 17, 2010 | 06:58 PM
ruff08's Avatar
ruff08
Angry Thanks
I will try again this week-end!! I pushed pulled pryed tool to point it broke I dont understand what hell the problem is? Think may put some WD-40 on line maybe rust r something keeping it from releasing R last person bent line.:-(
Old Jun 17, 2010 | 07:08 PM
White 97 xlt
Yep, it could be rust!! Drown it in PB Blaster for a day or two just in case.. But if you pull on the line before the garter spring is released it will just get tighter...
Old Jun 17, 2010 | 07:16 PM
lew52's Avatar
lew52
X 2 everone has the same problem , don't pull on the line till the clip is releast , push in on the line when it releases it will slide off....Lew
Old Jun 17, 2010 | 09:39 PM
greg213187's Avatar
greg213187
I had the same problem on mine sprayed a little PB blaster in there and then placed the tool in the fitting and used a screw driver behind it to get more pressure and it came off. Took a little bit.
Old Jun 17, 2010 | 10:10 PM
jrodimus's Avatar
jrodimus
I change a couple a day. Use some lubricant, a blast of compressed air will also free any debris from the "quick" coupler. Place the tool in position and pull the line toward the fuel filter while using a screwdriver to press the tool inside the coupler. You will feel the tool release the retaining clips inside the coupler and then push the tool and coupler away from the filter.
Hope this helps.
Old Jun 22, 2010 | 02:57 PM
ruff08's Avatar
ruff08
Fuel Filter and Line Replaced!!!!
I came to the conclusion after trying everything that I could to use a tubing cutter on fuel line before braided line in front and behind filter. Went to Pick-A-Part and found a 95 F-150 and cut the line in front of fuel filter and at the Y at front tank. Came hm and lowered the tank some and used a compression fitting from hardware store on the metal fuel lines to put back together!! I bought new retainers that go inside factory junk conectors at Auto-zone! By adding the longer line at back that I got at the bone yard, it pushed the filter forward where in the future if gives me problems changing filter it is easier to get to and if need be I can take loose at couplers and change on bench!!! Does anybody see any reason why this would not be safe? I drilled new holes in frame to mount the old filter bracket. Those retainers in old connector were bent by previous owner and thats why I could not use the tool to get it off, I quess plus **** poor design and location. Thanks for your help!!!!
TerranE
21
Jan 3, 2017 08:43 AM
4Cammer72
Nov 13, 2016 03:53 PM
joeinca
Jul 19, 2016 04:42 PM
old60fordman
New Member Introductions
Dec 7, 2009 10:15 AM
pickupman2002
Oct 12, 2005 04:09 PM
