plugs look good - really good. Running some Lucas injector cleaner now.
Where is the fuel filter on an '03 V8?
so you pulled all the plugs and they look good. how long have you owned the vehicle? I have never pulled all my plugs without replacing them with new ones. this is weird. I am going to the corner with my dunce cap. I must be an idiot for even trying to help on this thead
Take a deep breath, some people expect you to hold their hand and do all the work....
For not using the search
For exessive use of brevity (no model)
For not updating my profile
I do enjoy these forums, I am on several, for a lot of new and some very old vehicles I own. I really do apologize, had I not been rushing, I would have made this a much better post for all.
here is a link showing the ff on an exploror go to post #15 Fuel filter removal - Ford Explorer Ranger Enthusiasts "Serious Explorations"® yours should be simliar. you proably need the 5/16 tool , you can check when you buy the fuel filter or else just buy the set at AZ with all the sizes they are as cheap as $10. pull the fuel pump relay and then start the truck until it stalls. pop the fuel filter off wrap a rag around it so you dont get any in your eyes, wear goggle if you have them. reinstall the relay. These filters never seem to get changed , maybe becasue they seem like a pain but once you do it once it is pretty easy. also hit the filter with some rust penatrotor before removing it.
