injection pump replacement & auto trans
Old Jun 17, 2010 | 02:50 PM
downunder0323's Avatar
downunder0323
Replaced injector pump and now tranny will engage in all gears but will not go anywhere, what did I miss when I put the pump in and hooked everything up?
Old Jun 17, 2010 | 02:55 PM
Lazy K's Avatar
Lazy K
What transmission?
Old Jun 17, 2010 | 03:13 PM
downunder0323
C6 Auto, Always worked good until I replaced the pump
Old Jun 17, 2010 | 03:15 PM
downunder0323
This is a 1986 6.9 4x4
Old Jun 17, 2010 | 03:28 PM
powerstroker100's Avatar
powerstroker100
Is your FIPL sensor working? heres some stuff I have saved on my computer on how to test it,
*Hook up the negative lead of a volt meter to the battery ground and the positiove lead to the center GY/W (grey/white) wire which is the FIPL signal wire. I use a paper clip up the side of the wire in the connector. The FIPL must be attached to the wiring harness. Engine low idle speed must be set to specs prior to adjusting the FIPL. Auto 650 in drive, manual 650 in nuetral.
With a warm engine, key on, engine off, measure the voltage at the GY/W wire, if adjustment is required loosen either the bracket with bolts or just use the slack in the Torx screw holes. Now gently rotate the FIPL until you get some where between 1.05V and 1.1V. then tighten the torx screws or bolts which ever you loosened ensuring no movement of volt setting. Rotate the throttle lever slowly to WOT see if you get 3.8 V but not more than 4.3 V. Watch for any dead spots.
The large FIPL mounting bracket can be moved but ensure it is centered for a good rotation. Any adjustment should be made by only rotating the FIPL. If a new FIPL is required, check tang engagement as you take off the old FIPL and then make sure that the tangs in the new FIPL engage the throttle lever properly.
The closed throttle voltage: 1.1 V, ...wide open throttle voltage: minimum of 3.8 V but not more than 4.3 V.
Old Jun 17, 2010 | 05:04 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
no sensors for the c6 trans.its vacuum controlled.
Old Jun 18, 2010 | 04:21 AM
Lazy K's Avatar
Lazy K
About the only thing you could have done wrong is to either not connect the pipes to the vacuum regulatory valve or connect them the wrong way around.
However I would have thought, even if that was the case, the trans should at least drive in first.
Old Jun 18, 2010 | 06:02 AM
mistakenID's Avatar
mistakenID
Check your transfer case to make sure it isn't in neutral.
Old Jun 18, 2010 | 10:27 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
No FIPL, No Computer, It's a C6, Not a E4OD.
That could be embarrassing ... But it's a good answer.
-Enjoy
fh : )_~
Marauder2004
Jun 30, 2014 07:17 PM
BluePitt
34
Jan 9, 2012 06:52 PM
sillly402
29
May 22, 2009 09:14 AM
Truckboy
Mar 14, 2006 12:59 PM
Brando1980
Nov 12, 2005 06:04 PM
