can i replace my in tank pump with a mechanical pump
1985 F350 460
Replaced in tank pump once / now today fuel cutting out
relay under hood was hot!!!???
bad relay?
I would put a gauge on the fuel line and see if you lose fuel pressure at the time the engine cuts out. Could be a faulty relay but at least the gauge would eliminate the fuel pump.
From what I understand the reason for Ford changing to the electric pump was to eliminate problems with vapor lock on 460's. Electric pump pushes fuel from the tank, mechanical pump "sucks" fuel from the tank. To convert back to a mechanical pump you'd have to remove the electric pump and replace it with a pickup tube of some sort and replumb the fuel lines. Many times, the reason electric pumps fail is due to a clogged fuel filter which causes too much current to be drawn by the pumps. Be sure to check/replace the filter in the carburetor inlet as well as the one in the tank.
I will check pump and filters today. Truck has dump body easy to get to tank. Think I will replace relay also. I have a 1975 F350 400ci engine mach. pump never gave me the headaches the 460 has.
Replaced pump and relay - ran fine not cutting out
However relay still getting hot.
Might try the mech. pump looks easy. replace in tank pump with hose and some kind of filter for pickup - plumming for mach. pump seem easy. reading wire diagram for electrical pump system is nuts / oil switch two hots from switch and selonoid.
1983 E350 rockwood motor home with 460cu.in. hot fuel option would not pull itself up a small hill without missing real bad and at times shutting down. installed new 5-8 lb fuel pump it ran great untill one day while driving down the road it just shut down on level ground would not restart untill it cooled down. when it did it only ran about 1 mile and same thing! after reading in this forum about others problems i think it might be a relay getting hot and shutting fuel off trouble is i cant locate relay need help
The diagrams have been posted on the forums, unfortunately I can't recall exactly where right now. If you search for fuel pump or my username DBAPilotDad you should find them - on mine (single tank), the oil pressure switch is on the back driver's side of the engine (under the dog house), the fuel cutoff switch is on the passenger foot well and the fuel relay is under the hood behind the driver's side headlight on the fender wall.
On my 84 460 I was trying to put most of the fuel system back to factory and had a lot of problems but thats another story,anyway I had a mechanical fuel pump installed and left the new electric pump in the tank and just left it unpowered and everything worked fine and is still driving around with no problems of a vapor lock and no problems starting even if it sits for a long time.
