LMC has the parts also but, at least on the actuator pin, Dennis Carpenter is MUCH cheaper (DC P/N D0TZ-7B097-B $12.00, LMC P/N 43-7240 $39.95) On the switch itself there is 5 cents difference.
Ford obsoleted DOTZ7B097B earlier this year, I wonder if DC knows that.
When parts go obsolete, sometimes they can be bought from FoMoCo Dealers from between dealer net cost ($5.62) and the last MSRP which was $9.36
LMC is asking quadruple MSRP plus...for ONE. They prolly have none, and are only buying it as needed from one of the 65 FoMoCo dealers that still have stock.
Here is the illustration from the Ford parts book, the neutral start switch is basic part number 7A247 and the actuator pin is 7B097. The actuator clips to the shift tube and moves a pin that sticks out of the NSS that is attatched to the steering column with two very short screws (42120-S).
Click on the .pdf link to open the file.
I have a 1975 F150 and just finished replacing my shift collar. The pot metal was cracked were it aligns to the shift tube. Got it all back together, it shifted nice and smooth through all gears. I thought everything went pretty good until I tried to start the truck, no go. I had the shift tube out so I could fish the broken pieces out, could the actuator pin have fallen off? It appears as stated above that I have nothing moving my nuetral start switch. Also, how does this actuator pin mount to the shift tube, can you install it at the location of the nuetral safety switch. Do you think I should take all apart to see if it is hiding somewhere in the steering column. Thanks for any reply's.
it definately came off if you had the shift tube out
look on the floor, it's just a small kinda U shaped metal part that clips in the slot in the shift tube, no tools, just snap it in by hand, it's not a tight fit and feels loose, the spring in the N/S switch always has pressure on it to hold it in position
after installed, you may need to adjust the N/S switch to start in park and neutral
Brownfoot - I looked on the floor and under the mats last night after reading this original thread. Couldn't find it. I think it may be inside the steering column - taking it all apart again tonight to see. If it's in there I don't want it to bind on anything, maybe causing me more grief later.
Thanks for your reply....bruincup.
So where is this darn thing at? I have a78 f150 custom inline six 300 non tilt steering wheel and auto tranny. With no back up lights. My gear selector is kinda loose as well. Put new engine mounts in, and did the 8lbs in drive hanging from the selector and tightened it back up, but the selector is still loose and no back up lights. Any help,, well would help.
73-77 the switch is on the steering column. In '78 the neutral start switch was moved to the drivers side of the transmission. Its located where the shift arm comes out of the trans.
This is what it looks like.
So where is this darn thing at? I have a 78 F150 custom inline six 300 non tilt steering wheel and auto tranny. With no back up lights. My gear selector is kinda loose as well. Put new engine mounts in, and did the 8lbs in drive hanging from the selector and tightened it back up, but the selector is still loose and no back up lights.
As Mike said, 1978/79: NSS located on left side of trans case at manual control selector lever / But: C4 NSS is different than C6 NSS / 1978/79 F100/250 300 I-6 could have either a C4 or a C6.
C4 = 11 trans pan bolt holes, C6 has 17 / D8TZ-7A247-A .. C6 NSS (Motorcraft SW-1489) // D8TZ-7A247-B .. C4 NSS (Motorcraft SW-1491).
Optional tilt wheel operated via the T/S handle by pressing it forward. You probably don't have it as you have a Custom. Usually seen only on Ranger XLT's and Lariats.
AMC/GM/ChryCo used a separate lever to operate tilt wheel. No Ford truck has a separate lever until 1992.
Thank you gentleman. I didn't pay attention when i adjusted my gear selector. I plan on cleaning my frame ground strap later today so I'll take a look while I'm under there. I looked all around in the cab around the steering column. Thanks again.
My 79 NSS might of went out,would not turn over with the key.Opened the hood and jumped the solenoid,turn over/started.Time to test.Ing switch kind of loose/worn out,solenoid newish (5 years), and the NSS(4years),the last was full of junk(oil,dirt,smagg.)
Auto parts wants 80$,ebay wants 35$ for a NSS for my 79.
May just remove the NSS and connect the wires for start and add a switch for the reverse lights.
I just by passed it
Reason: got it started again
I have a 1967 Mustang neutral safety switch which is mounted on the c4transmission . Presumably it will also mount to the c6. on trucks it is mounted on the column and is a idiotic design because in time you have to dick around with the shift lever to start the truck. Has anyone converted their truck to use the Trans mounted neutral safety /reverse switch? That would sure eliminate a lot of aggravation. My 66 and my moms 76 same problem
C4 and C6 NSS look the same but are different.
In '78 Ford switched to the transmission mounted NSS on the trucks.
Occasionally the trans mounted switch needs to be adjusted too, like the column mounted switch.
If you're having problems with the column mounted NSS, it's simple to adjust. Loosen the two screws that attach it to the column and slide it right or left to adjust, then retighten the two screws.
Thanks for the good info. I'll try that. I'll do that the same time I upgrade the collar that holds the clear plastic prndl indicator so I can use the c6 indicator pattern instead of the green dot indicator.
How is the switch adjusted. I tried the pen and neutral and it doesn't seem to line up. Took the switch off and tried various positions and the truck will start. With the pin in the hole in back of the switch it will not line up.
