1978 - 1996 Big Bronco
Check Engine Light
Old Feb 6, 2003 | 09:10 AM
VIBR8R's Avatar
VIBR8R
Question Check Engine Light
My check engine light has been on. I was on my way home one day to replace the o2 sensors, floored it to pass a car and the light went off. After replacing only one of the sensors (the other was too damn hard to get to, didn't have time or patience), I was driving down the road and the light came back on. Could this be caused by the other sensor or some other problem? Also while slightly appling throttle there is a slight but noticeable skip could this be timeing or back to sensor problem?
Old Feb 6, 2003 | 12:31 PM
mrwizard's Avatar
mrwizard
Check Engine Light
Did you check to see what the code was before you changed the O2 sensor?
Old Feb 6, 2003 | 12:54 PM
VIBR8R's Avatar
VIBR8R
Check Engine Light
To what code are you referring?
Old Feb 6, 2003 | 02:58 PM
dblue351's Avatar
dblue351
Check Engine Light
Take it to a shop and have them run it for codes. Some will do it for free. Not many though. Mine was a air charge sensor on top of the intake. But it could be 100000 things!
Old Feb 6, 2003 | 03:03 PM
JBronco's Avatar
JBronco
Check Engine Light
Overfilling the fuel tank, a non-oem gas cap, or faulty gas cap can cause the check engine light to come on. It's easy enough to check anyway.
Old Feb 6, 2003 | 05:32 PM
bronco cam's Avatar
bronco cam
Check Engine Light
Is there a autozone close by? They will check your computer for codes for free. I have used them a couple of times. They come out to the parking lot and plug in there code reader and then tell you what the code means. You do not have to buy any thing. a shop will charge you from 50 to 80 bucks!!
Old Feb 6, 2003 | 06:46 PM
Roscoe1818's Avatar
Roscoe1818
Check Engine Light
No Shops!!! A little horror story of mine involving shops: took my f-150 to precision tune for a code check as it was spark-knocking randomly, cost $265 for....a throttle position sensor. bout $25 at Advance and 30min install. SHops are evil.
Old Feb 6, 2003 | 10:12 PM
steve83's Avatar
steve83
Check Engine Light
VIBR8R
If your vehicle is an '84-95 Ford truck (some specific vehicle info would be good ), you can pull the codes yourself anywhere with a paperclip.
Old Feb 7, 2003 | 08:45 AM
VIBR8R's Avatar
VIBR8R
Check Engine Light
sorry steve83 i forgot to put that in but here ya go - 96 bronco 5.0 xlt.
Old Feb 8, 2003 | 12:28 AM
dblue351's Avatar
dblue351
Check Engine Light
Originally posted by steve83
VIBR8R
That is easy to do, but the light flashing can be confusing.
Old Feb 8, 2003 | 10:39 AM
steve83's Avatar
steve83
Check Engine Light
Take it to a parts store - many now pull & clear OBD-II codes free.
YaBoiMileHigh
Mar 17, 2017 08:24 PM
m4ryj4y
Sep 10, 2015 01:44 PM
churioz
1983 - 2012 Ranger & B-Series
Mar 8, 2012 03:09 PM
Haroon
Oct 25, 2010 06:08 PM
intruder34
Modular V10 (6.8l)
13
Sep 12, 2008 03:39 PM
