installing brake controller on 04 expedition
Old Jun 16, 2010 | 01:50 PM
ohmar99's Avatar
ohmar99
Can any one give directions on installing an electronic brake controller on a 2004 4x4 expedition. I surrently only have the four flat in the rear.
Thanks
Old Jun 17, 2010 | 06:06 AM
FTE Trigger's Avatar
FTE Trigger
Thanks
Thread Moved to the Expedition/Navigator forum...
Old Jun 17, 2010 | 08:22 AM
ohmar99's Avatar
ohmar99
thanks, I did not see this forum but I figured a half ton truck would be the same.
Old Jun 17, 2010 | 03:06 PM
Ford54's Avatar
Ford54
I'm looking to do the same thing on my 05. I believe it's pretty easy if you already have the factory tow package.
I found a video of one being installed on an 07, but not sure if it's the exact same or not.
******** classid="clsid27CDB6E-AE6D-11cf-96B8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=7,0,0,0" width="350" height="323"><param name="wmode" value="transparent"><param name="movie" value="http://www.etrailer.com/tv/player1.swf"><param name="bgcolor" value="#000000"><param name="quality" value="high"><param name="menu" value="false"><param name="flashvars" value="currentfps=15.00&loopVideo=stopend&playOnLo ad=true&autobuffer=true&embed=false&videoUrl=http://www.etrailer.com/Merchant2/graphics/00000001/video/brake-contoller-install-2007-ford-expedition.swf"><embed src="http://www.etrailer.com/tv/player1.swf" flashvars="currentfps=15.00&loopVideo=stopend&play OnLoad=true&autobuffer=true&embed=false&videoUrl=h ttp://www.etrailer.com/Merchant2/graphics/00000001/video/brake-contoller-install-2007-ford-expedition.swf" type="application/x-shockwave-flash" pluginspage="http://www.macromedia.com/shockwave/download/index.cgi?P1_Prod_Version=ShockwaveFlash" width="350" height="323" bgcolor="#000000" quality="high" wmode="transparent" menu="false"></embed>*********><p style="padding-left:10px"><a href="http://www.etrailer.com/tv-brake-contoller-install-2007-ford-expedition.aspx">Trailer Brake Controller Installation - 2007 Ford Expedition</a></p>
Old Jun 17, 2010 | 11:05 PM
MC Expy's Avatar
MC Expy
I have a 05 and I bought the brake controller similar to what's in the video above. I never mounted it because I only towed my race car 10 times a year so I just plugged it in and laid it in the center console. Then just unplugged it when done.
Old Jun 18, 2010 | 06:35 AM
alwaysfords41's Avatar
alwaysfords41
You can't do it with a 4 pin, it doesn't have a brake wire. The pin that gets added for a 5 pin connector is the brake wire. Is the tow package you have aftermarket?
Old Jun 18, 2010 | 11:14 AM
ohmar99's Avatar
ohmar99
how can I tell
Old Jun 18, 2010 | 11:38 AM
alwaysfords41
The window sticker if you have it, a dealer can look it up by VIN to tell you, or you can look for the transmission cooler by the radiator (it looks like a smaller radiator). Both my 03 and 04 have factory tow and they both have 4 pin and 7 pin connections at the hitch. I have read somewhere (maybe here?) that they de-contented the tow package and had done away with the 7 pin connection, although the wiring for it remained in the harness at the hitch. Not sure when that happened, or if it did, just what I recall. Could have been a mid year '04 switch which is why mine has the 7 pin and yours doesn't.
Old Jun 21, 2010 | 08:09 AM
ohmar99's Avatar
ohmar99
it has a blue thick blue wire not hooked up behind the four flat coming from engine compartment
Old Jun 21, 2010 | 08:51 AM
alwaysfords41
Blue is the brake wire. Check out the etrailer site, maybe they have an adapter so you don't have to cut off the 4 pin connector and resplice all the wires. They have a lot of info on their site.
Old Jun 22, 2010 | 10:26 AM
ohmar99's Avatar
ohmar99
I do have the tow package. It is my understanding that I do not need the Big yellow and and the big black wires hooked up. They are just for back up lights and supply full 12 volts to trailer for charging external batteries on trailers or for sprayers. Only have blue wire back there.
Old Jun 22, 2010 | 11:21 AM
alwaysfords41
Yellow is normally the left turn signals and purple is the back up lights. Black (or red) is the battery charger. Back to your original question - you have a 4 pin plus blue which is what you need for a 5 pin connection to electric brakes. How you turn your 4 pin with a wire into a 5 pin for your trailer is up to you, I would cut the 4 pin off and splice in a true 5 pin. The electric brake controller will come with directions, but since you have the factory tow package it will be plug and play.
Old Jun 23, 2010 | 10:24 AM
ohmar99's Avatar
ohmar99
goter dun yesterday thanks for all your help
Old Jun 23, 2010 | 11:40 AM
alwaysfords41
Did you just cut the 4 pin off?
enriquemo2
All Things Towing
Jun 8, 2015 07:02 PM
hodges710
Oct 22, 2011 08:52 AM
Frankievespa
Apr 11, 2011 09:56 PM
afsigma21
1983 - 2012 Ranger & B-Series
Jun 12, 2009 02:27 PM
