Installing a brake controller
Old Jun 12, 2009 | 08:52 AM
afsigma21's Avatar
afsigma21
I want to install an Electronic brake controller in my ranger, so I can tow my camper short distances when I need to. The ranger is not my primary tow vehicle.
On my expedition there was a plug under the dash. I just wired the controller to a ford wiring kit and plugged it in. Do I have that option with a ranger? I bet not because I dont have a factory 7pin plug in the back.
Anyone ever installed one, what am I looking at for trouble spots?
2002 Ranger XLT 4.0
DOES have tow package
Old Jun 12, 2009 | 09:50 AM
5.0B2's Avatar
5.0B2
There should be a plug up under the rear bumper to the passenger side of the license plate area for the ford trailer plug harness to be added.
Old Jun 12, 2009 | 01:08 PM
Overkill-F1's Avatar
Overkill-F1
My '08 Sport 4x4 didn't have the plug for the 7-way harness, just the four-way. I had to add 2 wires (#10awg for 12v bat charge and #12awg for brake control) from the rear to the engine compartment. I placed two circuit breakers near the battery. The #10 wire goes thru one 30 amp circuit breaker and then connects to the battery. The second circuit breaker (20 amp) provides power to the controller. The #12 wire runs from the rear and into the cab to the controller.
...Terry
Old Jun 12, 2009 | 01:58 PM
afsigma21's Avatar
afsigma21
I think my greatest challenge will be to find the correct wire under the dash to splice into for the brake, to "actuate" the controller. I need to research this, but no idea where to start looking
etrailer has a complete kit with all the wiring and breakers and mounting hardware+plugs for $50, it seems the best way to go.
Old Jun 12, 2009 | 02:27 PM
Overkill-F1
My wiring diagram may help you find the correct wire on the brake pedal. You should have no trouble finding the switch above the pedal. One wire is 12 volt battery (light green/red) and one wire goes to the brake lites (light green). Connect the controller to this last one.
...Terry
EricNCSU1204
24
May 4, 2017 07:18 PM
KHAYES
All Things Towing
Jun 12, 2013 12:09 PM
rocknrod
1997 - 2003 F150
Dec 5, 2012 08:27 PM
1spitfire
2009 - 2014 F150
Aug 8, 2012 02:44 PM
thendawg
Jan 19, 2011 05:13 PM
