Converting to Hydroboost, looking for tips
Old Jun 16, 2010 | 03:19 AM
Opossum's Avatar
Opossum
Question Converting to Hydroboost, looking for tips
I already posted the following questions here; https://www.ford-trucks.com/forums/9...-for-tips.html and here; Converting to Hydroboost, looking for tips - Ford Truck Enthusiasts Forums But my truck mechanically is much more like yours then other 87-97 trucks. It's really just a 86 with different fenders. And well you guys seam more mechanical and less "does it look pretty" So I'm posting it here too looking for all the experianced info I can get before I spend more time and money then I have to doing the wrong stuff.
<HR style="BACKGROUND-COLOR: #d1d1e1; COLOR: #d1d1e1" SIZE=1> <!-- / icon and title --><!-- message -->
Well it sounds like my vacuum brake booster is giving up in my 87 F-350, it's hissing. So since I never liked the feel of vacuum boost and really hate this one. And like the feel of every hydroboost I've driven, along with the increase in braking power and some other vacuum concerns, it's time to make that swap.
So anyone out there who has done it? What parts did you use? What problems did you run into? etc.
From what I have read so far it looks like the easiest parts to use are from a 87-97 F-450/550, and that some have used 99 and up Superduty parts, anyone got any pros or cons on each set up?
Anyone used Chevy parts? any benifits? I can't imagine there is a function benifit and it's likely only that they are much more common for finding parts?
I know that the chevy unit has an accumulator so you have a few pumps after the engine stops, I'll admit I don't know much about the Ford unit does it have one also?
I have a small PS leak that I guess I'll fix at the same time, but how about the pump, any concerns there? I know I don't have the extra place for the second return line, not worried I can T it. But does it flow enough, and the resevoir is rather small. Is there a pump upgrade that is worth doing?
I think that's enough needy questions, thanks in advance for the help.
Edit, So I just found this great write up, in the 80-86 forum of course; https://www.ford-trucks.com/forums/8...-write-up.html and wanted to edit this while I could, still reading, asuming I've read it anyone got anything to add?
Old Jun 16, 2010 | 04:19 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Check out this thread:
FTE - Hydro boost brakes
-Enjoy
fh : )_~
FORDF250HDXLT
107
Mar 19, 2020 10:29 AM
strokin'_tatsch
76
Jun 15, 2018 05:27 AM
Cracker289
20
Jul 18, 2015 02:59 PM
BruteFord
31
Jun 7, 2013 12:06 AM
tuckerd1
Jun 24, 2011 07:34 PM
