bolt pattern quik question
Old Jun 15, 2010 | 10:22 PM
wizzy214's Avatar
wizzy214
got a 91 ranger
and got a set of 15" steel wheels their 5 x 4.5
will they fit?
not sure what their from.. whats the difference from ford and chevy rims?
thanks
Old Jun 16, 2010 | 12:45 AM
crerar's Avatar
crerar
Bolt Pattern Reference
may be helpful
Is your 91 a 2wd or 4wd
5 x 4.5 is the right size for a small ford wheel pattern (Ranger, Bronco II, explorer, aerostar). Hopefully your centre hole matches up.
Older full size ford pickups and vans are a larger 5-hole (5 x 5.5? - above website). As far as I remember, Chev hole pattern is same as bigger 5-hole ford, but center hole is different size.
Good luck! (and may you receive counsel from wiser folks than me )
Old Jun 16, 2010 | 03:23 AM
Rangerman Stan's Avatar
Rangerman Stan
wizzy214, short answer, yes if the center hole fits over your axle hub. The only other thing to look at would be the wheel offset, making the wheel sit outside the wheel well too much or maybe inward too much. The steel wheels you have could be from another Ford product or maybe a Jeep Wrangler, Liberty or Cherokee. Should be a manufactures stamp on it somewhere around the bolt holes. No 5 hole Chev wheel will fit any 5 hole Ford, either full size or mid size like S-10/Ranger.
cooljman1's Avatar
cooljman1
well as long at the back spacing is right then they should fit. I beleve that the chevy rims are 5x4.75
Old Jun 18, 2010 | 11:05 AM
racsan's Avatar
racsan
my winter rims are off a '01 jeep wrangler, slightly different offset. but they work, just tucked into the body a bit more. gm 5-lug patterns that im aware of are 5 on 5" and 5 on 4-3/4" here is my jeep steel wheels i run in the winter:
palace55
27
May 9, 2022 02:18 PM
fordka
Aug 7, 2014 09:35 PM
hhowell1990
May 18, 2012 08:37 PM
sixty9oz
1978 - 1996 Big Bronco
30
Mar 2, 2008 06:40 PM
RotGrubestier44
Offroad & 4x4
Oct 7, 2006 01:22 PM
