Steering line replacement? HELP!
Old Jun 15, 2010 | 10:07 PM
ciara shutt's Avatar
ciara shutt
Exclamation Steering line replacement? HELP!
okay I'm brand new here. The truck is my boyfriends, a 1982 f100 3.8l v6. he was messing around with something and broke the low pressure return, which is copper. i cant find the metal hose with the fittings ANYWHERE, and this truck is the only way he can get around. any suggestions?
Old Jun 15, 2010 | 10:28 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Welcome to FTE.
Maybe here LMC Truck - Power Steering Components
I'm sure there will be others along shortly with ideas as well.
-Enjoy
fh : )_~
Old Jun 15, 2010 | 10:37 PM
ciara shutt
thank you, i mostly need the fittings on the ends that are nowhere to be found online... and advanced and autozone dont have them in their computers either -_- (this is why i own a jeep hahaha)
Old Jun 15, 2010 | 10:38 PM
FordNFishinLover's Avatar
FordNFishinLover
I'd say check out the above link. But if he happened to break any of the plastic where the fitting goes onto the pump you will have to buy a new pump.
Old Jun 15, 2010 | 10:41 PM
ciara shutt
no he only broke the copper tube in the center.
the only thing hes worried about is replacing a copper tube with a rubber one because there is a threaded fitting on the end. from what it looks like you could just take it off and clamp the new one on but he insists that you cant put a rubber hose in there.
Old Jun 15, 2010 | 11:04 PM
FordNFishinLover
Heres another site, not sure if this what your looking for or not. Its also rubber though?
RockAuto Parts Catalog
Old Jun 16, 2010 | 12:27 AM
TheKirbyMan's Avatar
TheKirbyMan
Are you talking about the long metal tube that goes down underneath the engine?
I'm not sure where you'd buy that, BUT you shouldn't have much trouble finding one at a junkyard. They're not rare or anything, so you might be able to get one cheap.
For what it's worth though, this same tube has a break in it on my truck (that, or some dope cut it for some reason), and it has a length of rubber hose connecting the two halves. It's been that way for eight years and it's still working fine.
Old Jun 16, 2010 | 09:01 AM
81-F-150-Explorer's Avatar
81-F-150-Explorer
That part has been obsolete for a long time. I needed one almost 10 years ago now. What happens is the tube rubs the crossmember it's attached to, and wears a hole in it. It goes along the crossmember as a way of cooling the fluid off before returning it to the pump.
You can cut the bad section off and replace it with a rubber section no problem untill you find another in the wrecking yard.
Old Jun 16, 2010 | 09:19 AM
andym's Avatar
andym
There is no problem with replacing part of the tube with rubber hose.
Old Jun 16, 2010 | 07:22 PM
ciara shutt
thank you all for your help. I didn't think that there should be a problem changing it to a rubber hose. i was almost positive that it would be fine but he insisted, when i told him my dads '01 ford and my jeep have rubber hosing, "a rubber one wont work, its not a jeep its an old ford" -_-' sometimes i think he needs to realize that its pretty much just the same as any other car.
As far as putting a new piece on though, would you just cut off where he broke it and clamp the rubber hose on?
Old Jun 16, 2010 | 09:21 PM
andym's Avatar
andym
That's exactly what I would do.
Old Jun 16, 2010 | 09:31 PM
ctubutis's Avatar
ctubutis
Me, too. It's a low-pressure return line, a garden hose would work (though I don't recommend
using that, but it'd work).
Old Jun 17, 2010 | 11:07 AM
Festus Hagen
Methanoholic
Don't over tighten the hose clamps as so many do...
-Enjoy
fh : )_~
Old Jun 17, 2010 | 09:28 PM
ciara shutt
thank you all for your help! you guys are awesome!
Old Jun 17, 2010 | 11:14 PM
FordNFishinLover
Yea, yea. We know we know.
1986F150six
Oct 30, 2014 08:24 PM
abe
Apr 10, 2014 09:27 PM
GB SISSON
Jan 2, 2012 08:50 PM
ironman1892
Jun 20, 2010 03:24 PM
AXracer
47
Mar 14, 2005 08:26 AM
