Steering
To see of it is king pins jack the front and move the wheels while some one holds the steering wheel you will be amazed at the play in the tie rods and drag link.
Garbz
The usual cause for slop in the gearbox is the sector shaft bushing (B8A3576A = 1961/64).
There's only one, it's the same as passenger cars, and it's a "weak sister." By the time 40,000 miles rolls around, it's time for a new one.
If it were my truck, I'd just replace the bushing, the sector shaft seal (C7OZ3591A), and housing gasket (C3AZ3581A).
The costs for these three parts will be minimal, and this is a simple gearbox to work on. If additional parts are required, they can be found and are EZ to install.
Note that this is a different part [number] than 1961/64's (B8A3576A) use.
The seal and gasket are the same.
Tried to Rep you but was told I needed to spread it around.
<TABLE id=post7320288 class=tborder border=0 cellSpacing=1 cellPadding=6 width="100%" align=center itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD style="PADDING-BOTTOM: 0px; PADDING-LEFT: 0px; PADDING-RIGHT: 0px; PADDING-TOP: 0px" class=alt2 itxtvisited="1"><TABLE border=0 cellSpacing=6 cellPadding=0 width="100%" itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD noWrap itxtvisited="1">NumberDummy
Ford Parts Guru</TD><TD width="100%" itxtvisited="1"> </TD><TD vAlign=top noWrap itxtvisited="1">Join Date: Nov 2006
</TD></TR></TBODY></TABLE><!-- / user info --></TD></TR><TR itxtvisited="1"><TD id=td_post_7320288 class=alt1 itxtvisited="1"><!-- message, attachments, sig --><!-- icon and title -->1961/64 F100/250 2WD Steering Gear Parts
<HR style="BACKGROUND-COLOR: #d1d1e1; COLOR: #d1d1e1" SIZE=1 itxtvisited="1"><!-- / icon and title --><!-- message -->Quote:
<TABLE border=0 cellSpacing=0 cellPadding=6 width="100%" itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD style="BORDER-BOTTOM: 1px inset; BORDER-LEFT: 1px inset; BORDER-TOP: 1px inset; BORDER-RIGHT: 1px inset" class=alt2 itxtvisited="1">Originally Posted by Voodoo66
I am currently driving m '64 F100 everyday to work about 80 mile round trip. The only thing I dont like is that my steering box has too much slack
(This is a TYPICAL problem with Ford steering gears) and can't be adjusted out.
I do have manual steering boxes from '54 and '57 F100's...my question is would either one of these work for my '64?
No.
C3TZ3504U .. Manual Steering Gearbox / Obsolete (no one has any).
Fits: 1961/64 F100/250 2WD.
Why would you want to install another used steering gear?
It will not be any better....it could be worse.
NEW old stock genuine Ford parts can be found for your present gearbox, I've done this for members here dozens of times.
2) C2AZ3571A .. Steering Shaft Bearing.
GREEN SALES in Cincinnati OH has FOUR: 800-543-4959
ANTIQUE AUTO SUPPLY in Arlington TX has TWO: 817-275-2381.
PARTS INTERNATIONAL in Farmers Branch TX has THREE: 888-727-0418.
BOB ALLEN FORD in Overland Park KS has THREE; 800-676-0675.
TISON MOTOR SALES in Estill SC has THREE: 803-625-2551.
2) C2AZ3552A .. Steering Shaft Race.
GREEN SALES has FOUR.
ANTIQUE AUTO SUPPLY has THREE.
PARTS INTERNATIONAL has FIFTY.
BOB ALLEN FORD has THREE.
TISON MOTOR SALES has SIX.
1) B8A3576A .. Sector Shaft Bushing
ANTIQUE AUTO SUPPLY has ONE.
TISON MOTOR SALES has ONE.
JST AUTOMOTIVE in Lebanon TN has ONE: 615-443-3086.
KLIMESH MOTOR SALES in Calmar IA has ONE: 563-562-3241.
LYLE'S FORD-MERCURY in Eagle Grove IA has TWO: 800-397-6319.
1) C3AZ3581A .. Sector Shaft Seal
GREEN SALES has 113.
PARTS INTERNATIONAL has 14.
1) C7OZ3591A .. Housing Gasket
GREEN SALES has 84.
PARTS INTERNATIONAL has 50.
Usually just replacing these bearings, races and the bushing will make a world of difference.
You can install just these parts and see what happens.
If the play is still apparent, then you will have to replace the steering shaft and the sector shaft.
1) C1TZ3524A .. Steering Shaft (includes worm gear)
GREEN SALES has TEN.
BOWMAN FORD SALES in Bowman ND has ONE: 701-523-3257.
1) B8A3575A .. Sector Shaft
GREEN SALES has EIGHT.
ANTIQUE AUTO SUPPLY has TWO.
This is a very simple box to work on...I've overhauled dozens like this.
If a klutz like I can do...anyone can.
<!-- / message --><!-- sig -->__________________
Bill / Retired Ford Parts Manager / SoCal Chapter member / Part number research: 1928/2001 FoMoCo vehicles.
