I have a 2000 4x4 with the 7.3l. Going forward is fine, if I put a 6000 lb trailer and try and back it up a not so steep hill I have to put it in Lo to get it to go. Do I have an issue or is this normal. I always thought reverse was geared a little lower than first.
Is it a lack of power or do you think it's a trans problem?
It actually sounds normal to me. 6k trailer and a 8k vehicle is a lot of weight. I often put it in 4 low to do that very thing. I wish there was a way to switch to 2 low and not have to use 4wd.
