goes into reverse kinda slow??
Old May 23, 2005 | 02:12 PM
JF5speed's Avatar
JF5speed
I have a 4x4 96 x with the 4.0 motor and when i put it in reverse it takes a little longer to go in than when i put it in drive, is this a bad sign???
Thanks
Old May 25, 2005 | 09:18 AM
drcoffee's Avatar
drcoffee
Have you checked the fluid level? This would slow the shifting of the tranny. Could be line pressure issues.
Old May 25, 2005 | 02:12 PM
JF5speed's Avatar
JF5speed
yes its full, and i changed it
Old May 25, 2005 | 06:12 PM
drcoffee's Avatar
drcoffee
When did you change the fluid? It take a little while for the torque convertor to fill up and operate properly. Keep an eye on the fluid level. Also did you change the filter and install it properly? I don't mean to question your skills But the first post left a lot of info out. If it just started after your fluid change it is probably related. That was a nasty job by the way. I did mine 2 summers ago.
bertscova
Oct 9, 2009 04:26 PM
REDFORDFX4
2004 - 2008 F150
Sep 1, 2009 05:59 PM
Yougotthehit
Jan 9, 2009 01:52 AM
460f350
Jul 21, 2005 02:33 PM
ATC_250SX
Mar 4, 2005 10:15 PM
