Rear Window Washer Fixed
Old Jun 13, 2010 | 11:15 PM
Ex03AK's Avatar
Ex03AK
My rear window washer hasn't worked since I bought my Ex in '05. While installing headers this weekend I had to remove the fender well. Right there in front of me was the problem. The washer hose is attached to a plastic fitting that had come out of the grommet in the firewall and was just dangling. I put it back in, zip-tied it, and now it works.
If you have the same problem, you can tell if you purposely overfill the fluid reservoir and it leaks out under the front passenger door.
You could probably reach the fitting without removing the entire fender well. Just undo the aft side of the right front fender well where it bolts to the frame and pull it forward for access.
Zoomed out
Zoomed in
Old Jun 14, 2010 | 11:22 AM
wallz's Avatar
wallz
Good info. Another spot to look for when there is a brake in the line. Reps sent.
Old Jun 14, 2010 | 11:39 AM
dave91gt's Avatar
dave91gt
Sounds like my problem exactly! I guess I will pulling the fender liner out tonight.
Thanks!
Old Jun 14, 2010 | 07:26 PM
william_04_x's Avatar
william_04_x
Great post and pics. Thanks for the heads up..
Old Sep 13, 2010 | 10:15 PM
wakenup23v's Avatar
wakenup23v
Great post
Mine has not worked for over a year. I'll check it out later. I hope its the same issue.
Old Mar 19, 2011 | 08:17 PM
05MilMachine's Avatar
05MilMachine
Well add me to that club, however mine is leaking on the other side of that fitting, as it soaked the carpet on the passengers side and began dripping out all along the rail on that side. Must be leaking up high as it got the carpet wet from the front way up high. Thats probably the only feature I didnt check on the test drive.... doh!
Old Mar 19, 2011 | 08:21 PM
loleuiha's Avatar
loleuiha
Zoomed out
Zoomed in
Kool I hope this is my problem too...
Loleuiha
Old Mar 19, 2011 | 08:48 PM
GNRL LEE's Avatar
GNRL LEE
Mine was leaking on the inside passenger floor also. This was one of the easiest fixes ever. To bad it took me a year to look.
AlaskanEx
Oct 12, 2019 03:18 AM
03silverTJ
May 12, 2016 01:34 AM
wildstang
26
Sep 18, 2015 08:31 PM
pdombrowicki
Sep 14, 2012 07:54 AM
pdombrowicki
6.4L Power Stroke Diesel
May 29, 2010 07:40 AM
