Door hinges
Old Jun 11, 2010 | 05:26 PM
bade11's Avatar
bade11
Door hinges
Does anybody have any suggestions/tricks on how to replace driver side upper and lower door hinges on a 1996 F150?
Do i need to detach the wire harness?
Old Jun 11, 2010 | 05:31 PM
danr1's Avatar
danr1
Pins worn and loose? If so you can replace them easy enough. I haven't had to myself yet, just lucky I guess (that and a lube job now and then), but read plenty of threads here by those who have.
Old Jun 12, 2010 | 06:00 AM
TexasGuy001's Avatar
TexasGuy001
This is not too difficult. You can get the hinge pins in the HELP section at most autoparts stores.
This is easier with an extra set of hands. If you don't have that option, you can use something like a floor jack to prop the door on. I used a dremel and a cutoff wheel to cut the old ones and then knock them out. Do them 1 at a time.
Old Jun 12, 2010 | 06:21 AM
quicklook2's Avatar
quicklook2
google "hinge pin replacement on lincoln town car" for a good write up on how to do this.
Old Jun 12, 2010 | 11:03 AM
raystankewitz's Avatar
raystankewitz
Here's what I found:
Lincolns OnLine | Tech Tips and Articles
It looked like a good tutorial to me.
Ray
1LIFE
Jan 10, 2015 08:09 PM
mike330
Jan 15, 2008 07:46 PM
cujo8
Sep 3, 2007 07:48 AM
AggiePSD
Nov 26, 2002 04:24 AM
sauerf100s
Apr 1, 2002 08:28 AM
