I bought a 79 F150 300 Yesterday the guy said it had a little blow by> drove it 150 miles home checked the oil when i got home and it was 2 1/2 qts low so i e-mailed the guy and told him it used that much oil and he was shocked? He said the guy he got it from had a piece of rubber hose over the dipstick tube with a bolt in it and the dip stick was on the fender well and before i got there he put the dipstick in it. Is there any reason why oil would come out of dipstick tube?
Sounds like excess crankcase pressure (blow by). With the excess oil consumption, a likely possibility is worn (very worn) or damaged (broken) rings.
Does it smoke out the exhaust? With a quart almost every 50 miles it should be either smoking incredibly bad or leaking like a sieve.
Another possibility is the crankcase vent system is plugged up. You can check the PCV valve but as cheap as they are it's easier and more reliable to just replace it.
There is no smoke but where the breather cap on the valve cover is they ran a long chunk of hose run down along the engine why they would do this is beyond me. So the breather is not plugged either the engine was over hauled recently. I guess they tried other breather caps also. How do I check pcv valve? or just change it
To me the long hose would be a clue that probably after they rebuilt the engine they had a bad problem with blowby and were trying to "band-aid" the problem.
My guess (and that's all it can be) is that the rebuild was done incorrectly. Either the rings are installed wrong, didn't seat properly or were damaged on installation or initial start-up.
I would suggest running a compression test and see what happens.
My 302 V8 does the same thing, I have a rubber hose coming off the dipstick tube and going into a oil container and the reason being is oil was being shoved out the dipstick tube and spraying all over. But it don't use the amount of oil that you're going through..
Sounds like somebody may have put news rings in a wore out egg shaped/oversized cylinder and called it good and it didn't work out for them.
My diesel tech teacher always said "You know why engines don't last as long after they have been rebuilt? People don't read the manual and check all the specs like they are supposed to".
I know you didnt rebuild the engine yourself but just a little advice for future use. Don't cheap out on a engine rebuild b/c it will end up costing you more b/c you will have to rebuild it again shortly down the road.
