Sponsored by: Real Truck
rear hub nut size?
Old Jun 9, 2010 | 06:11 PM
ak-angler's Avatar
ak-angler
rear hub nut size?
I'm getting ready to replace the bearings in the rear of my 2003 f250. Can anybody tell me what size the four-point hub socket is for the hub nut? I have a couple of four point hub sockets, but I want to make sure I have one that fits before I tear it apart, since I won't exactly be able to drive to the tool store once I do.
Old Jun 10, 2010 | 02:37 AM
ak-angler's Avatar
ak-angler
I'm sure somebody knows...
Old Jun 10, 2010 | 05:38 AM
tnvnl's Avatar
tnvnl
Go to your local Napa store, it takes a special socket for that application. Thats where I got mine, it was $59.00.
Old Jun 10, 2010 | 11:54 AM
ak-angler's Avatar
ak-angler
I know it takes a special "castle" socket. I own a couple. Just looking to see if I have the right size before I open it up. I don't want to buy one if I already have the right size. Also don't want to tear it open if I don't have the right one.
Old Jun 11, 2010 | 07:15 AM
tnvnl's Avatar
tnvnl
Tearing it apart consists of removing the axle, about 5 minutes of time, lifting is not necessary, nor removal of rear wheels, then, if your current sockets are not the right size, 5 minutes to put axle back in. well worth the time if your not sure about your sockets.
Old Jun 11, 2010 | 10:38 AM
JockD's Avatar
JockD
I was doing some research the other day and came up with Ford tool #205-448. OTC #6601. Most places list this as 2003-up F250 & F350, but my 2001 service manual calls out the 205-448 for my truck. I suspect that it fits all 1999 and up Superdutys.
Old Jun 11, 2010 | 12:32 PM
ak-angler's Avatar
ak-angler
Well, since nobody seems to know what size it is, I'll just go buy one and return it if I don't need it.
Old Jun 11, 2010 | 01:49 PM
aldridgec's Avatar
aldridgec
I'm not even sure how you would specify size for these. I usually order them by application not size, and then just grab whichever works.
Old Jun 11, 2010 | 07:26 PM
ak-angler's Avatar
ak-angler
Well, a measurement across the outside diameter of the socket would have worked. Or center of pin to center of pin. Inside diameter. Whatever. Doesn't matter now. I bought one already.
BDalton
24
Feb 27, 2017 10:26 PM
Kris with a K
Nov 7, 2016 12:21 PM
Kris with a K
Nov 2, 2016 10:45 AM
NotURMailman
Mar 23, 2016 04:22 PM
Fusion
Mar 16, 2003 01:01 AM
